Re: Interference between torsion bar & tie rod end link
[Re: autoxcuda]
#830503
10/15/10 10:38 PM
10/15/10 10:38 PM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
I had to shim the steering box to get everything where it belonged. The MP Chassis manual explains how and why. My driver side inner tierod end was hitting the torsion bar and the centerlink was rubbing the oilpan. Bumpsteer was real bad. Everything is fine now.
[Re: cruzin]
#830505
10/15/10 11:27 PM
10/15/10 11:27 PM
Posts: 27,552 So Cal
autoxcuda
So Cal
GomangoCuda,
I hadn't consider this!!! I'm trying to think if the original box was shimmed when I removed it. If so, would it have been shimmed with those square-ish looking horse-shoe shaped shims? I sort of recall seeing these now that I'm thinking about this.
Yes they would have been horse shaped shims typically.
A car with stock parts shouldn't need those. I wonder if something is bent somewhere?
[Re: BDW]
#830508
10/16/10 11:19 AM
10/16/10 11:19 AM
autoxcuda
So Cal
Wouldn't a shim move the box up? Making the problem worse?
If you just shim the top bolts and not the bottom ones the box tilts down.
[Re: cruzin]
#830510
10/16/10 07:33 PM
10/16/10 07:33 PM
Posts: 28,096 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Is the center link horizontal? If not, either the pitman arm or idler arm are incorrect. They should be at the same distance off the ground. That means they should be the same height from the frame rails too.
JohnRR referred to this but in an odd manner. The idler arm and pitman arm do not set ride height. However, they are the points that are supposed to be measured to set the ride height.
My money is on the center link being installed backwards or upside down.
[Re: cruzin]
#830512
10/16/10 11:05 PM
10/16/10 11:05 PM
feets
Senior Management
Senior Management
Irving, TX
I'm running a 69 B-body k frame in the hot rod. My pitman arm is about an inch below the torsion bar. The tie rod actually sits below the T-bar with the wheels centered. That's pretty far off from where you're at.
[Re: cruzin]
#830513
10/16/10 11:12 PM
10/16/10 11:12 PM
Posts: 18,165 Mass
DAYCLONA
Mass
Cruzin,
From your photo it appears you have the wrong end of the centerlink assembled, it appears that you have the idler arm end assembled to the pitman arm end,....the pitman arm end should be angled rearward, and have a slight forward pitch looking from the rear,...the idler arm end is somewhat straight,....as I'm sure your aware there is no way to install the centerlink upside down, because of the joints taper,....but it's easy to swap the wrong end,...a photo taken looking straight up at the centerlink would confirm,.....
Mike
[Re: BigTerry]
#830514
10/17/10 11:49 AM
10/17/10 11:49 AM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
shouldn't the hole the tierod end go into be chamfer??
Yes so there is no way it would be upside down unless he has the wrong pitman arm.
Update.. Interference between torsion bar & tie rod end
[Re: JohnRR]
#830515
10/18/10 03:25 PM
10/18/10 03:25 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
** Update ** Over the weekend it appears that I got this problem squared away. I wish the problem was as simple as having the center link reversed or flipped or a bent part, as some had suggested. However, that was not the case.
What I did was obtain another new pitman arm (third one) and replaced it. Also, I shimmed the top bolt on the new steering box. Not sure if the shim was necessary however, it appeared to add a slight amount of clearance and it doesn't seem to affect anything so I left it in when I re-torque the steering box. The new pitman arm was Moog same as the prior two, new ones. Comparing them side by side, and taking some measurements with a caliper, I could not find any significant difference. Apparently, Moog sources these parts from other vendors since none of them had an actual Moog part # as far as I could tell. All I can say is upon reassembling and torquing everything back up, wall'la no more interference!
Anyway, thank s for everyone's help and suggestions.
