Re: 4 bolt master CLY and brackets to a 2 bolt
[Re: Dakota_Don]
#830472
10/15/10 09:29 PM
10/15/10 09:29 PM
Posts: 4,743 Florida
BDW
[Re: BDW]
#830473
10/16/10 01:19 AM
10/16/10 01:19 AM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
[Re: rhad]
#830475
10/16/10 03:54 PM
10/16/10 03:54 PM
Posts: 47 wv
dakster
wv
[Re: dakster]
#830476
10/16/10 08:29 PM
10/16/10 08:29 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm not sure about the AR engineering adapter but I put the Mopar adapter on my wife's 72 charger's power booster.
I had to grind the corners of the adapter a little to fit the booster and then plenty of trial and error with readjusting the push rod int the booster so it would reach into the MC.
I used rear end marking compound on the tip of the push rod, installed the master on to it (tight as if it were installed) and then took it apart to check how much transfer I had.
Adjust until the transfer goes away and then bring the adjuster back slowly until it barley contacts or maybe even a slight gap.
Best pic I have
