Page 1 of 4 1 2 3 4
Hemi Oil Pump #829788
10/14/10 06:41 PM
10/14/10 06:41 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
I need help to get the right pump cover & hope someone
I have a World aluminum block which has the pickup plumbed directly into the block. I will use this for the single feed external line from the sump/pickup to the block.
I want to run an Remote Oil Filter, so which pump cover should I use? I have the Milodon 21815 pump.?
I want to retain the original engine mounts (Hemi/B-Body).
Hope someone can help.!
Darren Beale
Keith Black Racing Engines®
Re: Hemi Oil Pump [Re: Keith Black®] #829789
10/14/10 06:42 PM
10/14/10 06:42 PM
QLD Australia
QLD Australia
whoops typo.. *hope someone can help!
pic of pump:
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829790
10/14/10 06:55 PM
10/14/10 06:55 PM
detroit area
moderncylinder Offline
detroit area
actually with that pump you cannot use the pickup hole in the block,, you have the fitting comming right off the pump,, use it
Re: Hemi Oil Pump [Re: moderncylinder] #829791
10/14/10 07:03 PM
10/14/10 07:03 PM
QLD Australia
QLD Australia
ok thanks, any clues on the cover to use?
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829792
10/14/10 07:48 PM
10/14/10 07:48 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Geeeze Darren, you just have to send me an email...
With the 21185 pump you use the 21220 or the 21230 cover. The 21220 has the second inlet from the back, and the 21230 has the second inlet from the side or the back, but the covers are interchangeable.
Remember the intermediate shaft is different with the pump.
You would use 21503 for a steel gear and 21523 for the bronze gear.
The remote filter fittings are -10 o-ring on the cover and -10 or -12 AN male for the lines. The covers do not include the fittings.
Re: Hemi Oil Pump [Re: Mopar_Rich] #829793
10/14/10 09:52 PM
10/14/10 09:52 PM
QLD Australia
QLD Australia
thanks Rich . It looks like the #21230 is the best option, as it relates to retaining existing engine mounts.
the pickup line from the pan goes to the front of the pump (the pickup hole at the front of the engine block is to be blocked off, as is the pickup flange inside the crankcase).
It would be useful to see a picture of filter out/in if someone has one with the #21230.
Drive gear noted, will need the bronze one. I'll make a trip to Earl's for the fittings. At least we have one of those stores in Australia not much else when it comes to Hemi's.
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829794
10/14/10 10:01 PM
10/14/10 10:01 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
This pump and cover assume TWO oils lines from the pan, and yes, block off the extra inlet if it's a World block.
Re: Hemi Oil Pump [Re: Mopar_Rich] #829795
10/14/10 10:49 PM
10/14/10 10:49 PM
detroit area
detroit area
if you look at the pump, it has no provision to pickup any oil from the mounting surface on the block which is why i said you cant use the hole in the block,, that pump will actually block it all off just bolting the pump on,, id block off the external hole but the internal hole is no big deal. put a plug in the one you dont use on either the cover or pump, though id use the one on the pump,, i think its easier to fill the rotors comming from the back side,, ive tried both with a single line to 9000 rpm and seen no differnce in oil pressures
Re: Hemi Oil Pump [Re: Keith Black®] #829796
10/14/10 10:56 PM
10/14/10 10:56 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
pic of pump:
If you want only 1 oil feedline you can run a stock pump cover with that pump. Which is what I use on my dart.
Re: Hemi Oil Pump [Re: Twin Turbo Mower] #829797
10/15/10 12:48 AM
10/15/10 12:48 AM
QLD Australia
QLD Australia
I would think the stock cover doesn't support a remote filter setup?
Darren Beale
Re: Hemi Oil Pump [Re: moderncylinder] #829798
10/15/10 12:59 AM
10/15/10 12:59 AM
QLD Australia
QLD Australia
if you look at the pump, it has no provision to pickup any oil from the mounting surface on the block which is why i said you cant use the hole in the block,, that pump will actually block it all off just bolting the pump on,, id block off the external hole but the internal hole is no big deal. put a plug in the one you dont use on either the cover or pump, though id use the one on the pump,, i think its easier to fill the rotors comming from the back side,, ive tried both with a single line to 9000 rpm and seen no difference in oil pressures
So with the right cover I could feed the external line coming from the Pan into the rear of the pump (and block off the 2-front inlets one being in the pump itself and the other in the front of the block which will be blocked anyway with this pump) Correct ..??
If this is the case that'd be a clean install & the best for my application.
I assume in/out ports for the remote filter are thosee two ports on the front-leading edge of the pump cover?
Rich ...I think that'd be either of both of pump cover #21210 or #21200 ??
Darren
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829799
10/15/10 01:15 AM
10/15/10 01:15 AM
Mt.Vernon IL
Mt.Vernon IL
I run a stock cover with the milodon pump you have pictured up top, and I thought summit sold a kit that worked with a stock cover. I could be wrong.
Re: Hemi Oil Pump [Re: Twin Turbo Mower] #829800
10/15/10 01:22 AM
10/15/10 01:22 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
Not my own experience but I have had two noted Mopar engine guys, DLI and RBRE, personally tell me that pump is problem child due to the aluminum body. They said it is too easy to flex it when you tighten the bolts.
Re: Hemi Oil Pump [Re: Keith Black®] #829801
10/15/10 01:24 AM
10/15/10 01:24 AM
AndyF Offline
AndyF  Offline
This is the cover I use. It has #12 AN fittings machined into the cover with a straight shot to the external oil lines.
Re: Hemi Oil Pump [Re: AndyF] #829802
10/15/10 01:26 AM
10/15/10 01:26 AM
AndyF Offline
AndyF  Offline
Installed in the car.
Re: Hemi Oil Pump [Re: AndyF] #829803
10/15/10 01:28 AM
10/15/10 01:28 AM
QLD Australia
QLD Australia
Andy, I want one!!
Do you make those...?
will it work with Milodon pump?
Darren
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829804
10/15/10 05:28 AM
10/15/10 05:28 AM
P
PasiR Offline
PasiR  Offline
P
You probably can´t use Andys pump cover with stock motor mounts.
Re: Hemi Oil Pump [Re: Mopar_Rich] #829805
10/17/10 04:48 PM
10/17/10 04:48 PM
QLD Australia
QLD Australia
Does this mean I "have" to run two pickups from the pan , or will I get by with just one?
Darren Beale
Re: Hemi Oil Pump [Re: Keith Black®] #829806
10/17/10 05:19 PM
10/17/10 05:19 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...My understanding is 2 lines are not needed unless you're going over 7,000 rpm.
Re: Hemi Oil Pump [Re: Keith Black®] #829807
10/17/10 06:17 PM
10/17/10 06:17 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I always run two lines because I like the security of the extra oil feeds to the pump. But I have also dynoed many engines with just one line and I have never had a problem with only one line either.
Page 1 of 4 1 2 3 4
