Best Primer ?? #826812
10/10/10 09:42 PM
10/10/10 09:42 PM
Toronto Ontario
Butt Ugly Offline OP
Toronto Ontario
Just blasted some steelies.
Any metal primer will do the job before paint or is there a " Best Primer for the Job"
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Best Primer ?? [Re: Butt Ugly] #826813
10/10/10 09:52 PM
10/10/10 09:52 PM
IN
ahy Offline
ahy  Offline
IN
Best over clean steel is epoxy. Next best is self etching primer. Self etching is available at many home improvement stores and autoparts stores. Epoxy and self etching are available at your local autobody supply store, Eastwood and "Colorlibrary.com".
Re: Best Primer ?? [Re: Butt Ugly] #826814
10/10/10 10:00 PM
10/10/10 10:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The best is etch primer first then epoxy on top of that. etch primer can't be used by it's self, it has to be top coated by another primer.
Re: Best Primer ?? [Re: Butt Ugly] #826815
10/10/10 10:57 PM
10/10/10 10:57 PM
Jacksonville Florida
elitecustombody Offline
^ I agree.
I think you're a little too late, you should have the primer by the time the wheels were done blasting
Re: Best Primer ?? [Re: elitecustombody] #826816
10/10/10 11:25 PM
10/10/10 11:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Any decent primer and paint system should work, just don't mix and match brands to be safe.
Steel wheels usually start rusting down inside the groove where the center and the outer hoop meet since it's difficult to get enough paint down inside the hole. Before I primed mine I set the wheels on the ground and poured a little primer into the groove and rolled the rim around until the joint was coated 360 degrees.
