Re: Project "69 Twin TurboCharger"
[Re: stumpy]
#825848
10/22/10 06:20 PM
10/22/10 06:20 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Problem with that is the ammount of heat blowing back on the radiator and engine.
actullay there's enough room to put them almost beside the rad. My car has no head light buckets so I have a TON of room. You could also shield them if needed. I guess it depends on the size and the amount of boost you want to run.
[Re: Mr.Yuck]
#825849
10/23/10 09:53 AM
10/23/10 09:53 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It also depends on how much you want to cut up the car. A radiator support is a pretty important piece of the car's structure. Hacking it will seriously weaken the front of the car. If you plan on stuffing turbos up there hacking will be required. If you try to run the plumbing under the support your ground clearance will be greatly reduced. Forget about pulling up to parking curbs and entering steep driveways.
[Re: feets]
#825850
10/23/10 01:00 PM
10/23/10 01:00 PM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
I plan on mounting the turbos near each valve cover, route the charge pipe threw the front upper "A" arm acentric bolt adjustment hole, into twin air to water coolers located in the fender, Then back into the engine bay by going under the frame just in front of the k member. Should require no cutting of fenders, just relocate all accessorys, radiator, and a bunch of heat shields. The charge pipe will be 2" out of the turbos and 2 1/2 - 3" from the coolers to the intake. It will cause no ground clearance issue as the the k member will be lower than the pipe...
[Re: Wilde Racing]
#825851
10/24/10 02:06 AM
10/24/10 02:06 AM
feets
Senior Management
Senior Management
Irving, TX
Running them in front of the radiator support will cause ground clearance issues. Doing it your way should not.
Doing it your way will present other issues.
1) How are you going to reach your spark plugs? I used those access holes or had to jack up the car and get under it.
2) Will your tires clear the piping when turned? Keep in mind that the tires need room to move vertically when turned. The piping will have to turn sharply upwards and run to the top of the fender and then forward so the tire doesn't make contact.
[Re: feets]
#825852
10/24/10 11:11 AM
10/24/10 11:11 AM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
Not too worried about the plug access at the moment, I'll build the headers to allow room for plug removal. It may not be easy but I figure, once this pig is up and running I'll only need to pull the plugs to check them every once and a while. It will be running Wide band Closed loop fuel control... As far as the tire clearance.... I didn't even think of that lol.... ![](/ubbthreads/images/graemlins/blush.gif) IF I cant get the tires to clear, I'll be forced to cut a small hole in the fender well closer to the front of the radiator support. I plan on making this car hold a turn as well as run 9's so the front tires can't just be little pizza cutters... I was just using those holes because it would be less intrusive if I were to ever return the car to a more stock restoration.....
[Re: Wilde Racing]
#825855
10/25/10 04:10 PM
10/25/10 04:10 PM
feets
Senior Management
Senior Management
Irving, TX
I strongly suggest you make accessing the plugs a priority! It really sucked to have to wait for the exhaust to cool before I could pull the plugs or check for loose wires. Those nifty Mechanix gloves don't cover arms and elbows.
[Re: pete]
#825861
10/29/10 03:44 PM
10/29/10 03:44 PM
Posts: 4,594 Motor City
6PKRTSE
Motor City
Very cool to see what you have done so far. I am in the process of gathering parts for my twin turbo, Alum Keith Black, twin plug Hemi, Drag Radial project Challenger. Sorry, no good pictures, just on my cell phone of the parts so far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: pete]
#825862
10/29/10 10:29 PM
10/29/10 10:29 PM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
Tues. is probably fine, but I will have to wait until Mon. to verify that I'm not working. Pete
Give me a cal if you'd like once you find out monday
775-530-8756 Dusty
[Re: Saskabusa]
#825864
12/07/10 02:56 AM
12/07/10 02:56 AM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
Thats quite the project. What are you going to use for electronics/ engine controller? Are you using the Edelbrock stuff?
Nope, I'll be using the latest Megasquirt stuff with LS1 coil on plug.
A little update,
I got my new (used) alternator. 130amp Denso, and a rebuilt Sanden r12/r134 a/c pump. I've been on vacation and have been working on a side project so nothing else has been done.... But IF my little side project works out, I'll have a nice 1949 Rockwell/Delta band saw that cuts up to 6" of metal....
