71 Duster Gas Tank hose? #82580
07/01/08 09:20 AM
07/01/08 09:20 AM
Sterling Heights, MI.
murfman Offline OP
super gas
murfman  Offline OP
super gas
Finally found why Duster was dying and then would start a few minutes later then die again! Soft gas hose between sending unit and hard gas line was kinked and preventing fuel flow. It really is a tight turn and I'm sure unless I can find OEM molded gas line it will kink again. Anyone know of a source for OEM line? Thanks
Re: 71 Duster Gas Tank hose? [Re: murfman] #82581
07/01/08 11:25 AM
07/01/08 11:25 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
original was not molded.
Re: 71 Duster Gas Tank hose? [Re: 05dakota] #82582
07/01/08 01:04 PM
07/01/08 01:04 PM
murfman Offline OP
super gas
murfman  Offline OP
super gas
If not molded any idea how I can make sharp bend in this 6 inch fuel line without it wanting to kink in the middle?
Re: 71 Duster Gas Tank hose? [Re: murfman] #82583
07/01/08 01:19 PM
07/01/08 01:19 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I just put a gas tank in my Duster and the straight rubber hose worked fine. Make sure you are using the thick nylon reinforced fuel hose and not the plain rubber vapor hose. The thick fuel hose is very hard to kink.
Re: 71 Duster Gas Tank hose? [Re: murfman] #82584
07/01/08 04:02 PM
07/01/08 04:02 PM
P
Paul_Fancsali Offline
P
Use EFI Fuel hose it will not kink without effort
