vibration, bent axles? (kind along)
#825387
10/09/10 12:52 AM
10/09/10 12:52 AM
Posts: 4,518 Indiana
MonGoo$e
Indiana
73 Duster, rebuilt everything nearly, balanced motor, shift- kitted 904 thats been beefed, recut and balanced driveshaft, rebuilt rear, as is bearings and seals. New Cragar wheels fresh balanced, Poly trans and Motor mounts.
Issue: at about 55-60 I have a "feel it in the lower back against the seat buzzy vibration..someone of a fluxuation. I'f I ease into 65-70 the feeling increases some but I detect towards rear of car a steady, somewhat up-tempo flux with the vibration. the lower portion (not the top mind you) gets a little 'buzzy'..any more than 70 and the lower have of the dash is shaking rather badly. seems most of the problems are at that belt line of the car. kinda odd.
I have a feeling it's the axles because at 5-20 what I have a sorta "bumpiness" to the ride as if the springs are to tight but I don't think it is, even though they are new HD..it's a bump bump bump.....bump bump bump pattern. But I'd like input, first time I've really had it up to speed for any rate of time. Rear is 8 1/4 and the axles were never checked or anything. Everything else is pretty fresh, whats it seem like first? thanks
Re: vibration, bent axles? (kind along)
[Re: MonGoo$e]
#825388
10/09/10 01:00 AM
10/09/10 01:00 AM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
put the car up in the air and have a buddy accelerate to those speeds while you are behind it. Look at the wheels and see if they're wobbling. I'm in a similar situation right now.
I could visibly see the wheels wobbling while the car was in the air. Gonna pull the axles tomorrow and have them checked out.
Have you checked your pinion angle though?
[Re: chache876]
#825390
10/09/10 02:06 AM
10/09/10 02:06 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Do all of the above. And look at the whole drive train front to back while under rotation. mike
[Re: RV2]
#825396
10/09/10 09:09 PM
10/09/10 09:09 PM
MonGoo$e
Indiana
put car in air, jack stands under the diff. I put car in gear. my driver wheel was straight at an "idle" spin, and when i ran it up to about 2000-2500 rpm. the passenger side was another story, it would wobble at the idle spin, and it got bad the more i went, the center cap was noticeably off center too. my friends dad was an ASE mechanic for 35 years, he looked at it during all this and said it has to be the axle with it moving that much at the hub. Later on I thought I'd like to be sure, would it be "safe" to rub in idle with wheels off and lugnuts on to hold the drums? I'd like to see if it's obvious there.
thanks for the help.
oh, when i tightened suspension, I put the shocks, springs, and axle in just enough to hold, dropped car down on it's weight and tightened everything. I was aware that was important on the front end parts and applied that to the rear of car as well.
[Re: MonGoo$e]
#825397
10/09/10 09:21 PM
10/09/10 09:21 PM
RapidRobert
Perfectly legit check, do it & holler back. EDIT dont forget to hit the brake to stop everything before you go into Park or from a forward gear to reverse or vice versa
