gear drive dog bone fell out?? #824429
10/07/10 06:16 PM
10/07/10 06:16 PM
Maryland
cudaboone Offline OP
Maryland
Anyone running a gear drive, have the dog bone fall out from between the cam gear and crank gear. I tried again to send pic of what it looked like when i took the cover off but apparently my pics are jpg and this site only downloads img.
Re: gear drive dog bone fell out?? [Re: cudaboone] #824430
10/07/10 06:47 PM
10/07/10 06:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: gear drive dog bone fell out?? [Re: cudaboone] #824431
10/07/10 08:31 PM
10/07/10 08:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If the dog bone failed, it was either a failure of the thrust buttons on each gear, or someone ground the back of the thrust buttons too far, as the assembly relies on each thrust button to keep the assemble from contacting the rear/face of the block,...or the main thrust gear (larger dia) was installed on the wrong side, causing the dogbone to "walk" forward off the cam and crank gear,.....
here's how it should look in respect to gear orientation
