727 front pump leak #820943
10/03/10 05:21 PM
10/03/10 05:21 PM
TN
SCATPACK 1 Offline OP
TN
will restricted pressure cooler line cause the front seal to leak. the front pump vent is plugged and a vent has been relocated to the rear of the housing. everything in the trans is new. and a pro trans brake. I just noticed the cooler line is kinked.
Old Geezer Racing
Re: 727 front pump leak [Re: SCATPACK 1] #820944
10/03/10 07:46 PM
10/03/10 07:46 PM
TN
TN
Old Geezer Racing
Re: 727 front pump leak [Re: SCATPACK 1] #820945
10/03/10 07:51 PM
10/03/10 07:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Where is it leaking from? The seal?
I could see a kinked cooler line cuasing excess line pressure that could result in a leak.
Fix the line, dry the trans, run it and inspect. If it is around the seal area (as is most common) you may also want to inspect the bushing and the conv snout.
Re: 727 front pump leak [Re: SCATPACK 1] #820946
10/03/10 07:55 PM
10/03/10 07:55 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
In my opinion no,, several causes are bad pump seal,,torn gasket between pump and housing,,gasket's on the pump to housing bolt's,, and of course the dredded cracked converter hub,,the most common is the seal as it's easy to nick when putting the converter in.
Re: 727 front pump leak [Re: WILD BILL] #820947
10/03/10 08:09 PM
10/03/10 08:09 PM
TN
TN
I have replaced the seal twice and it still appears to be leaking from the front. Can't be 100% positive, but it sure looks to be coming from the front seal.
Old Geezer Racing
Re: 727 front pump leak [Re: SCATPACK 1] #820948
10/03/10 08:44 PM
10/03/10 08:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If that's the case then most likley the support bushing in the pump is worn.
Could also be a cracked hub but I'ld start at the bushing.
Re: 727 front pump leak [Re: WILD BILL] #820949
10/03/10 11:06 PM
10/03/10 11:06 PM
TN
TN
bill and dartman thanks for the input. I put a new bushing, a new pump gasket, a new pump seal, I checked the hub when I had the pump apart. how many qts with a 8" converter. I have a 1 1/2 qt over size pan.
Old Geezer Racing
Re: 727 front pump leak [Re: SCATPACK 1] #820950
10/04/10 12:05 AM
10/04/10 12:05 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Hard to say if any leaked out of the conv.
I'ld start by filling till the dip stick shows some red then start the car and check in Nuetral till it's where you want it.
Re: 727 front pump leak [Re: WILD BILL] #820951
10/04/10 12:11 AM
10/04/10 12:11 AM
TN
TN
I will try that. thanks for the input.
Old Geezer Racing
Re: 727 front pump leak [Re: SCATPACK 1] #820952
10/04/10 02:16 PM
10/04/10 02:16 PM
Sweden
Cuda_70 Offline
Cuda_70  Offline
Sweden
Yes, restricted cooler lines could cause the front seal to leak.
Re: 727 front pump leak [Re: Cuda_70] #820953
10/04/10 05:19 PM
10/04/10 05:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Please explain how.
Re: 727 front pump leak [Re: John_Kunkel] #820954
10/04/10 07:59 PM
10/04/10 07:59 PM
Sweden
Cuda_70 Offline
Cuda_70  Offline
Sweden
A couple of years ago I was out for a test ride with my new 440 engine and had a problem with a leaking front seal on my 727. I could drive at the highway without any problems but if I stopped and raised the rpm (Turbo Action J-conv) for a testrun it just pissed trans fluid out of the front seal.
After some investigation I found that the front cooling line was bent more than it normally is (stock cooling lines). I just bent it back with my hands and went out for another test and the problem was gone.
I'm not a 727 guru so correct me if I'm wrong, if you plug the front cooling channel (= the output to the cooler), the oil flow from the converter will be to big so the front seal could start leaking, you will have the same problem if the front bushing/bearing have moved and restrict the channel for the oil flow.
Re: 727 front pump leak [Re: Cuda_70] #820955
10/04/10 08:37 PM
10/04/10 08:37 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
The only way restricted cooler lines could cause a leak out of the front would be for the trans to overheat and push fluid out of the vent.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 727 front pump leak [Re: zzyzxpat] #820956
10/04/10 09:13 PM
10/04/10 09:13 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
There is also a pipe plug that has been loose in most 727's that I rebuilt, I always wrap it with teflon tape before tightning it
Mitch
Re: 727 front pump leak [Re: 500ciDuster] #820957
10/05/10 01:10 AM
10/05/10 01:10 AM
TN
TN
well like I said everything is new inside the trans. I corrected the kink in the pressure line. Then I drained and refilled with 3 qts initially, adding slowly until its was full enough. I do not know. Im going to take it out and take it to my trans expert and watch him fix the problem. Im trying to make it to clay city.
Old Geezer Racing
Re: 727 front pump leak [Re: John_Kunkel] #820958
10/05/10 10:49 AM
10/05/10 10:49 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Please explain how.
I'm with John on this one. oops, sorry just realized you responded.
Re: 727 front pump leak [Re: Cuda_70] #820959
10/05/10 07:07 PM
10/05/10 07:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The flow in and out of the converter is behind the bushing which is behind the seal, so that scenario would have to push the excessive flow past the fairly tight clearance of the bushing before reaching the seal which has a drain channel back to the pan.
As stated earlier,a clogged cooler line could cause overheating which might push fluid out the breather but not past the front seal.
Re: 727 front pump leak [Re: John_Kunkel] #820960
10/05/10 07:34 PM
10/05/10 07:34 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I too am curious what would cause this leak. Mine was leaking and when we had the motor out you could see dampness under a couple of the pump bolts. I replaced the rubber coated washers and still had a leak. Pulled it back apart. Converter is completely dry on outside. Looked like the seal around the pump was the problem. replaced the gasket, o ring, seal, pump washers and put back together and guess what??? Yep, still leaking. I have a blanket on the trans and was wondering if it may be blocking the vent and causing a problem???
Randy
Re: 727 front pump leak [Re: Dartin] #820961
10/06/10 01:13 AM
10/06/10 01:13 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Did you PRESSURE check the converter? Mine had no visible cracks but 25 - 30psi in the snout and some water around the weld showed a crack that was over 1/2 way around right in the middle of the weld. The firast time I checked I was so sure it was fine that I put a new pump seal and bushing in, moved the vent to the rear, put it all together, tested it, and had to tear it back out again.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 727 front pump leak [Re: SCATPACK 1] #820962
10/06/10 09:18 AM
10/06/10 09:18 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I had the same problem. But mine only leaked on start up. Problem was the bushing had spun in the pump housing. I replaced the housing and bushing, problem solved.
