rear end alignment #820359
10/02/10 11:41 PM
10/02/10 11:41 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
i havent been here in a while and just wanted to ask about alignment of my rear.....years ago i mini tubbed and did the move the springs inboard 3 inches and just realized its out of wack....last sept i went to the track and my driverside slick grew and rubbed on the front of my fenderwell.....so i took some measurements from wheel to wheel and came up with 3/4 of an inch forward on the drivers side compared to the passenger side.....i was talking with a buddy and he said to get a better measurement was to take it off the torsion bar frame mounting.....what do you think??
Re: rear end alignment [Re: GEORGE68HEMIRR] #820360
10/03/10 01:12 AM
10/03/10 01:12 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Think he is right
Re: rear end alignment [Re: stateline] #820361
10/03/10 01:40 AM
10/03/10 01:40 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Think he is right
Agree. Your front end could be out of specs too. On the frame are holes that the factory used for measurements. Use the front t-bar/transmission crossover frame or another spot that can not have moved.
You may need to weld in steel plugs in one or both of the spring mounting holes, redrill it on center of the correct measured spot. I think I would also weld a 3"X3" square with the same ID hole over the new hole to help support those steel plugs. Just me.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: rear end alignment [Re: Dave_J] #820362
10/03/10 10:51 AM
10/03/10 10:51 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
thanks dave.....thats what i was going to do for the fix
Re: rear end alignment [Re: GEORGE68HEMIRR] #820363
10/03/10 04:06 PM
10/03/10 04:06 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Actually, you need to find the suspension centerline, which is a measurement from the pivot points of the suspension at all four corners of the car.
I will try to explain how to find a centerline for the suspension system. This can also be found in the door-slammer chassis book by Dave Morgan.
Raise the car high enough you can get under it easily - since we will be working with the suspension pivot points, it doesn't matter if the supports are under frame or the suspension. Try to keep the car level.
First, find the "center" of the car. Use a string and plumb-bob to transfer these points to the floor. On the back of the car, hang the string from the leaf spring front bolt. Doesn't matter if its the inside or outside of the spring, as long as you do the same on both sides. (on 4-link or ladder bars, use the front hiem joint)
Lower the Plumb-bob to the floor and make a mark (black sharpie worked best). Repeat for the other side. Measure the distance between the two points on the floor and mark the center. Measure 2-3 times if necessary to get it accurate.
Move to the front of the car. Hang the string off the pivot bolt on the lower control arm. Again front or back, inside or outside doesn't matter as long as you use the same point on both sides. Mark the floor directly below these points. Measure between them and mark the center.
Using a chalk line, snap a line from front bumper to back bumper across the two center points. You now have the exact center of the suspension system. Using the plumb-bob you can now measure the distance of anything on the car from the center line. Hopefully the ends of the axles are even, but points on the body will probably be off some. I like to use the front of the brake register on the axle.
Now we need a line perpendicular to the centerline to be able to measure whether the suspension parts are square with the suspension centerline as well as centered.
Using a piece of string about 3 feet long, tie one end to the marker, hold the other end on the center line near the center of the car. Mark an arc or semi circle (which extends to both sides of the car. Move the string down the centerline about a foot one way or the other and make an arc in the opposite direction). These two arcs should cross near the outside of the car. Span the chalk line over the two intersection points and you should have a precise perpendicular line.
Now you can measure front to back from the perpendicular line to the rear axles and front rotors (or any other parts) to insure everything is square in the car.
Scott
Re: rear end alignment [Re: ProStDodge] #820364
10/03/10 10:51 PM
10/03/10 10:51 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
SCOTT....thanks for explaining all that....it sounds like the way to go and then it will be done correct...cool ..thanks
Re: rear end alignment [Re: GEORGE68HEMIRR] #820365
10/03/10 11:16 PM
10/03/10 11:16 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Don't bother with all that welding and drilling your shock plates or what ever that guy was trying to say. unless you are WAY off put shims between the forward leaf spring mount and the body to move the one side back until the axle is square.
Re: rear end alignment [Re: Dave_J] #820366
10/04/10 12:08 AM
10/04/10 12:08 AM
I'm gong to do that also as my rear is shifted too far sideways as is. ProStDodge, good info that I will for sure save as I want it spot on
Re: rear end alignment [Re: mercman1] #820367
10/04/10 01:41 AM
10/04/10 01:41 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I see, just Micky Mouse it and all should be OK. Do it how you want.
65 Formula S Cuda
Re: rear end alignment [Re: Dave_J] #820368
10/04/10 12:49 PM
10/04/10 12:49 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
EDIT: But when he moved the springs into the frame rails, there is no longer a front hanger. The holes replaced the hangers. So he must get the holes in the right place.
If its off just a bit, elongate the holes to where it needs to be and weld up the bad side.
You need this to be right with no slop. If you have some slop they will move no matter how tight you get the bolts. Do you want your rear springs moving around when you got both front wheels off the ground???
65 Formula S Cuda
Re: rear end alignment [Re: Dave_J] #820369
10/04/10 12:56 PM
10/04/10 12:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The way I have handled critical alignment holes that were mispositioned or elongated is to intentionally elongate the holes, add oversize washers to the bolts, position everything precisely then tack the washers in place....
Re: rear end alignment [Re: ProStDodge] #820370
10/05/10 08:29 PM
10/05/10 08:29 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
well i did as you said.....leveled car...plumbed down from pivot points and rear spring hangers ...snapped a center line and used a framing square to draw lines for rear end reference and figured out my rear is off 1 7/16....so if i slide it over to the right 3/4 of an inch she will be square.....also slotted spring bolt hole and moved rear back 3/8 of an inch....now all i have to do is figure out my pinion angle....right now the trans is minus 5 and the pinion is at 0 degrees......maybe i should minus the pinion to -2 degrees to get me right......what do you think???.....i am cutting and rewelding new saddles on
