Porportioning valve ? #819625
10/02/10 07:55 AM
10/02/10 07:55 AM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
Any ideas on where to get a porportioning vavle for a 68 Dart? It is a six cylinder car with manual drum brakes. A used one in good shape would be a possibility if someone has one also. Thanks, Clint
Re: Porportioning valve ? [Re: 80arrow] #819626
10/02/10 09:08 AM
10/02/10 09:08 AM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
Google "in-line tube" they make metering blocks and proportining valves for all makes.
kenny b
Re: Porportioning valve ? [Re: 80arrow] #819627
10/02/10 01:17 PM
10/02/10 01:17 PM
it's only a splitter block with a bung for the pressure switch.
Its separating the front from the rear, they changed to the split system so you wouldn't lose all braking during a hose or general failure in the one or the other fnt/rear systems.
