SWAPPING BASE PLATES AND MAIN BODIES
#819433
10/01/10 10:01 PM
10/01/10 10:01 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
any one know the rule of thumb when swapping carb parts.
such as what MB on what BASE result in a 950 cfm , 850 cfm , 750 cfm etc
thanks
WAXER
Re: SWAPPING BASE PLATES AND MAIN BODIES
[Re: QWK_ENUF]
#819434
10/02/10 01:21 AM
10/02/10 01:21 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
thanks
A 950 is basically a 750 MB with an 850 base, But the bottom of the bores on the MB are opened too 1.3/4 to match the base, they share the same 1.3/8 ventury opening, the 750 is 1.11/16 on the bottom & matches the 1.11/16 base.
An 850 is 1.9/16 on the opening too 1.3/4 on a 1.3/4 base.
A 750 is 1.3/8 too 1.11/16 on a 1.11/16 base.
