Hemi valves #817917
09/29/10 08:01 PM
09/29/10 08:01 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
What are the best valves to use with Stage V replacement heads-
Ferera/Manley/Others?
If anyone has part numbers it would be appreciated.
Darren Beale
Keith Black Racing Engines®
Re: Hemi valves [Re: Keith Black®] #817918
09/29/10 08:03 PM
09/29/10 08:03 PM
QLD Australia
QLD Australia
int 2.25
exh 1.94
will be using Stage V rockers.
Darren Beale
Re: Hemi valves [Re: Keith Black®] #817919
09/29/10 08:13 PM
09/29/10 08:13 PM
detroit area
moderncylinder Offline
detroit area
i usually use ferrea 1538/1539 they are like .100 longer for more install height and .250 tips
manley intakes are better material though if you are beating the crap out of it
Re: Hemi valves [Re: moderncylinder] #817920
09/29/10 08:19 PM
09/29/10 08:19 PM
QLD Australia
QLD Australia
thanks appreciate your help, mostly street use, although heads will be ported (will talk to you separately about this), roller hyd. cam, 250/262 @.050/ .700 lift. F2 proCharger max 15lbs boost.
Any benefits to longer valve other than installed height? i.e. geometry correction?
appreciate your help.
Darren Beale
