Re: "Don't ask me how I know..."
#813
07/16/03 02:50 PM
07/16/03 02:50 PM
I know how to break a new camshaft by having valve springs with too much spring pressure!
#814
07/16/03 03:12 PM
07/16/03 03:12 PM
Posts: 36 In
ply426
In
My plastic oil pressure guage line,hot hemi headers and budwieser did not mix,,,,,, DONT ASK ME HOW I KNOW!!
One of the greatest cover-ups of the last century was the fact that Hitler did not commit suicide in his bunker, but was in fact tea-bagged to death by Chuck Norris.
[Re: ZIPPY]
#815
07/16/03 03:42 PM
07/16/03 03:42 PM
When using an aftermarket cruise control on the freeway, DO NOT pop it into neutral just to see what will happen. I actually don't know exactly what happens but I have an old roommate that does.
#816
07/16/03 03:49 PM
07/16/03 03:49 PM
a 5HP go-cart wont turn 90 degrees at full throttle.....
OUCH! ROTFL
[Re: Just Cameron]
#817
07/16/03 04:11 PM
07/16/03 04:11 PM
The cops do not like it if you set fire to your own car at midnight on a backcountry road and leave it there. Creates a B I G arson investigation.
[Re: amxautox]
#818
07/16/03 05:11 PM
07/16/03 05:11 PM
Posts: 3,482 Cold Spring, NY
1970GTX
Cold Spring, NY
Never put wax into a solder pot designed for lead sinkers, they get a smidge too hot for the wax and it goes up in flames. Always ensure that the drain plug is back in the oil pan before adding any oil. Never manual shift a C4 that's behind a 351 Cleveland, they lock up in gear. Never put a 24 volt lamp into a socket designed for a 120 volt lamp, it goes off like a flashbulb. Don't ask me how I know
[Re: 1970GTX]
#819
07/16/03 06:37 PM
07/16/03 06:37 PM
If you happen to connect the dash light hot wire to the ground lug on your lighter, the dash lights will go on when you push the lighter in.....also note, the dash light fuse will blow instantly when you turn the lights on. Don't ask me how I know.
Dan
[Re: 1970GTX]
#820
07/16/03 06:53 PM
07/16/03 06:53 PM
Posts: 571 Fischer, TX
dodgepu360
Fischer, TX
I am gonna have to try that
[Re: oleman]
#823
07/16/03 10:06 PM
07/16/03 10:06 PM
......that those pants dont make her butt look fat. even if it is.
#824
07/16/03 10:33 PM
07/16/03 10:33 PM
CudaCharger is going to be pissed, after I get my motor in the 69RR "Don't ask me how I know"
#825
07/17/03 01:31 AM
07/17/03 01:31 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
This just in: Don't leave paper towels laying around engine compartment. Said towel gets blown back into the alternator and little bits get stuck inside, causing a "zzzzzzzzzzzzzzzzzz" sound. Please, don't ask.
Eric
[Re: Erics5th]
#826
07/17/03 01:33 AM
07/17/03 01:33 AM
Dropping your brand new wing nut that held on the air hat right down one of the butterflies of your throttle body will make you immediately feel dumber than you've ever imagined possible. Not me, but a very poor friend
[Re: AdamMopar]
#828
07/17/03 02:34 AM
07/17/03 02:34 AM
If you have gas line freeze up, warming up gasoline on the stove to pour into the tank is not a good idea. Unless you and your neighbours want to be homeless. Only in Montreal.
[Re: AdamMopar]
#831
07/17/03 12:02 PM
07/17/03 12:02 PM
Posts: 26,561 Santa Rosa, NOR*CAL.
Just Cameron
When cutting trees, make sure that it is not going to fall in the direction of the controls of a bulldozer that is running, especially when it's pointed at a building. It tends to make big holes in building. Don't ask me how I know. Adam
NICE! I thought that sort of thing only happened in movies. Got my vote.
