How in the world do I tighten the power steering belt? #815269
09/26/10 08:32 PM
09/26/10 08:32 PM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
My Dad bought a 79 Jeep J10 with the 258 6cyl. The power steering pump appeared to be squealing when the wheels were turned. I checked it out and the belt is very loose. I looked at this crazy setup for about half an hour before I ever started messing with it. The pump unit itself has 6 bolts. 4 in the front and 2 in the rear. The pump bolts inside of a bracket, if I loosen all 6 bolts on the pump it doesn't help with the adjustments a bit, and I can't figure out how to get the bracket loose. This thing just does not make sense..........help me here guys!!
Re: How in the world do I tighten the power steering belt? [Re: BarryBum] #815270
09/26/10 11:50 PM
09/26/10 11:50 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Try Googleing it. Ask the question a bunch of ways to get the best results. I find lots of info that way.
Re: How in the world do I tighten the power steering belt? [Re: BarryBum] #815271
09/26/10 11:56 PM
09/26/10 11:56 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
Does one of the brackets mount to the front of the pump, behinde the pully, if so, did you go through the pully and loosen those bolts? I'm not familiar with jeeps in perticular, but some setups are this way. You can go to your parts store and look at a new one to get some ideas if you just can't figure it out. There is probably just one bolt that you couldn't see. Get a small merror or use your wifes compact if you have to. There may be a tensioner pully that you might have missed also.
DRIVE EM, DONT HIDE EM.
