Can you paint a vinyl top? #815227
09/26/10 07:48 PM
09/26/10 07:48 PM
central PA
mopartial Offline OP
central PA
My just redone white vinyl top took some brake fluid from vehicle on lift above. It's ugly and it won't come off. Any ideas?
If it aint broke, dont break it.
Re: Can you paint a vinyl top? [Re: mopartial] #815228
09/26/10 08:16 PM
09/26/10 08:16 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
You can repaint it or better yet re-dye it. Call your local upholstery shop, preferably a well know shop that's been around a while. But you should probably just bite the bullet and get another one put on. That brake fluid will bleed through whatever you put on the top...eventually.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
