Page 11 of 15 1 2 9 10 11 12 13 14 15
Re: "Don't ask me how I know..." #813
07/16/03 02:50 PM
07/16/03 02:50 PM
I know how to break a new camshaft by having valve springs with too much spring pressure!
Re: "Don't ask me how I know..." #814
07/16/03 03:12 PM
07/16/03 03:12 PM
In
P
ply426 Offline
ply426  Offline
P
In
My plastic oil pressure guage line,hot hemi headers and budwieser did not mix,,,,,, DONT ASK ME HOW I KNOW!!
One of the greatest cover-ups of the last century was the fact that Hitler did not commit suicide in his bunker, but was in fact tea-bagged to death by Chuck Norris.
Re: "Don't ask me how I know..." [Re: ZIPPY] #815
07/16/03 03:42 PM
07/16/03 03:42 PM
When using an aftermarket cruise control on the freeway, DO NOT pop it into neutral just to see what will happen. I actually don't know exactly what happens but I have an old roommate that does.
Re: "Don't ask me how I know..." #816
07/16/03 03:49 PM
07/16/03 03:49 PM
a 5HP go-cart wont turn 90 degrees at full throttle.....
OUCH! ROTFL
Re: "Don't ask me how I know..." [Re: Just Cameron] #817
07/16/03 04:11 PM
07/16/03 04:11 PM
The cops do not like it if you set fire to your own car at midnight on a backcountry road and leave it there. Creates a B I G arson investigation.
Re: "Don't ask me how I know..." [Re: amxautox] #818
07/16/03 05:11 PM
07/16/03 05:11 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
Never put wax into a solder pot designed for lead sinkers, they get a smidge too hot for the wax and it goes up in flames.
Always ensure that the drain plug is back in the oil pan before adding any oil.
Never manual shift a C4 that's behind a 351 Cleveland, they lock up in gear.
Never put a 24 volt lamp into a socket designed for a 120 volt lamp, it goes off like a flashbulb.
Re: "Don't ask me how I know..." [Re: 1970GTX] #819
07/16/03 06:37 PM
07/16/03 06:37 PM
If you happen to connect the dash light hot wire to the ground lug on your lighter, the dash lights will go on when you push the lighter in.....also note, the dash light fuse will blow instantly when you turn the lights on. Don't ask me how I know.
Dan
Re: "Don't ask me how I know..." [Re: 1970GTX] #820
07/16/03 06:53 PM
07/16/03 06:53 PM
Fischer, TX
dodgepu360 Offline
dodgepu360  Offline
Fischer, TX
I am gonna have to try that
Re: "Don't ask me how I know..." [Re: dem440c] #821
07/16/03 07:52 PM
07/16/03 07:52 PM
twin cities
dart_sportsatellite Offline
twin cities
...a box end wrench is not the tool of choice for installing tranny cooler lines...
ROTFLMAO!!!!
Re: "Don't ask me how I know..." #822
07/16/03 09:37 PM
07/16/03 09:37 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
I you are towing a VW Beetle behind a motor home and it comes disconnected, you will not have it at your next gas stop.
VW Beetles do not like to be towed at 60 mph when the are left in 2nd gear. Really warms up the engine even with the engine off.
Re: "Don't ask me how I know..." [Re: oleman] #823
07/16/03 10:06 PM
07/16/03 10:06 PM
......that those pants dont make her butt look fat. even if it is.
Re: "Don't ask me how I know..." #824
07/16/03 10:33 PM
07/16/03 10:33 PM
CudaCharger is going to be pissed, after I get my motor in the 69RR
"Don't ask me how I know"
Re: "Don't ask me how I know..." #825
07/17/03 01:31 AM
07/17/03 01:31 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
This just in: Don't leave paper towels laying around engine compartment. Said towel gets blown back into the alternator and little bits get stuck inside, causing a "zzzzzzzzzzzzzzzzzz" sound. Please, don't ask.
Eric
Re: "Don't ask me how I know..." [Re: Erics5th] #826
07/17/03 01:33 AM
07/17/03 01:33 AM
Dropping your brand new wing nut that held on the air hat right down one of the butterflies of your throttle body will make you immediately feel dumber than you've ever imagined possible. Not me, but a very poor friend
Re: "Don't ask me how I know..." #827
07/17/03 02:28 AM
07/17/03 02:28 AM
Central Iowa
AdamMopar Offline
AdamMopar  Offline
Central Iowa
When cutting trees, make sure that it is not going to fall in the direction of the controls of a bulldozer that is running, especially when it's pointed at a building. It tends to make big holes in building. Don't ask me how I know. Adam
Good up and coming paint and body site. http://p2forum.proboards56.com/index.cgi?board=general
Re: "Don't ask me how I know..." [Re: AdamMopar] #828
07/17/03 02:34 AM
07/17/03 02:34 AM
If you have gas line freeze up, warming up gasoline on the stove to pour into the tank is not a good idea.
Unless you and your neighbours want to be homeless.
Only in Montreal.
Re: "Don't ask me how I know..." #829
07/17/03 11:50 AM
07/17/03 11:50 AM
NC
DARTSPORT340 Offline
super gas
super gas
NC
Never use the Map light switch under your dash as a disconnect for a tach that is draining you battery...switch is not insulated an will arc out against dash causing a small fire and burning up tach and a battery cell causing battery not to charge any more...
Re: "Don't ask me how I know..." [Re: AdamMopar] #830
07/17/03 11:58 AM
07/17/03 11:58 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I think we have a winner here!
Everybody makes fun of a hillbilly until they need something fixed
Re: "Don't ask me how I know..." [Re: AdamMopar] #831
07/17/03 12:02 PM
07/17/03 12:02 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline
NICE! I thought that sort of thing only happened in movies. Got my vote.
Re: "Don't ask me how I know..." [Re: Just Cameron] #832
07/17/03 12:04 PM
07/17/03 12:04 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
make that 3
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
