Re: 69 Road Runner spring special rallye green
[Re: desotoman]
#813915
09/27/13 08:09 PM
09/27/13 08:09 PM
Posts: 82 new york
desotoman
new york
heres a pic of my 69 ralley green car
[Re: badblack68]
#2042389
03/31/16 12:11 AM
03/31/16 12:11 AM
Posts: 2 Lethbridge Alberta, Canada
gdrill
Here's reviving a old thread. I have been researching this color as my car has it, I think. It is paint code 99 99. It has a build date of Nov 21 which I believe is in 1968 making it a fairly early car and certainly not in the spring where I live! This is the only pic I have access to right now but the sequence number under the bolt is 123417. This would make me think sp stood for special not spring. But I'm still learning about it. I am trying to add a link to photobucket but I'm not very good at this stuff! <a href="http://s996.photobucket.com/user/Fittythree/media/Mobile%20Uploads/image_zpsu7lichco.jpeg.html" target="_blank"><img src="http://i996.photobucket.com/albums/af89/Fittythree/Mobile%20Uploads/image_zpsu7lichco.jpeg" border="0" alt="69 RR fender tag photo image_zpsu7lichco.jpeg"/></a> http://i996.photobucket.com/albums/af89/Fittythree/Mobile%20Uploads/image_zpsu7lichco.jpeg
Two things I know for sure: 1 - I don't know everything, 2 - Nobody else does either!
[Re: gdrill]
#2043287
04/01/16 03:05 AM
04/01/16 03:05 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Here's reviving a old thread. I have been researching this color as my car has it, I think. It is paint code 99 99. It has a build date of Nov 21 which I believe is in 1968 making it a fairly early car and certainly not in the spring where I live! This is the only pic I have access to right now but the sequence number under the bolt is 123417. This would make me think sp stood for special not spring. But I'm still learning about it. I am trying to add a link to photobucket but I'm not very good at this stuff! I've been tracking 1969 99 paint cars. Beginning in October and through December, it appears there was a sizeable number of green and orange Road Runners built at the LA plant. 99 'Green' was not a 'spring only' release. Cars in that color are found in the fall of '68. Given the small production at the LA plant, 99 paint Road Runners, as a percentage of cars produced, seems to run much higher than the Lynch Road or ST. Louis Plant.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#2046668
04/04/16 10:32 PM
04/04/16 10:32 PM
Posts: 596 Nashville, Tennessee
Tempest
Here's reviving a old thread. I have been researching this color as my car has it, I think. It is paint code 99 99. It has a build date of Nov 21 which I believe is in 1968 making it a fairly early car and certainly not in the spring where I live! This is the only pic I have access to right now but the sequence number under the bolt is 123417. This would make me think sp stood for special not spring. But I'm still learning about it. I am trying to add a link to photobucket but I'm not very good at this stuff! I've been tracking 1969 99 paint cars. Beginning in October and through December, it appears there was a sizeable number of green and orange Road Runners built at the LA plant. 99 'Green' was not a 'spring only' release. Cars in that color are found in the fall of '68. Given the small production at the LA plant, 99 paint Road Runners, as a percentage of cars produced, seems to run much higher than the Lynch Road or ST. Louis Plant. "Spring Special" (or A14) is not point in time. It's an option on '69 Road Runners. Was a fairly rare option depending on hard top or post cars.
[Re: badblack68]
#2046844
04/05/16 02:25 AM
04/05/16 02:25 AM
gdrill
Thanx for the replies guys. I have an important project ahead. This color has really grown on me. I love it.
[Re: badblack68]
#2221531
12/27/16 06:23 AM
12/27/16 06:23 AM
Posts: 712 California
BigDaddy440
California
I believe I own the very first A12 "Code 97 Rallye Green" Roadrunner. 17th 6bbl RR off the Lynch Road Assembly Plant. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) The restoration is a work in progress...coming along though. ![](http://i66.tinypic.com/sl7fvp.jpg)
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2221538
12/27/16 09:02 AM
12/27/16 09:02 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
I believe I own the very first A12 "Code 97 Rallye Green" Roadrunner. 17th 6bbl RR off the Lynch Road Assembly Plant. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) curious, based on what? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Cars were not built in VIN order & 9A246399 would've been the 17 VIN sequence assigned to a "M"-code Road Runner. Does someone have a build order list?
[Re: 6bblgt]
#2221704
12/27/16 05:24 PM
12/27/16 05:24 PM
BigDaddy440
California
I believe I own the very first A12 "Code 97 Rallye Green" Roadrunner. 17th 6bbl RR off the Lynch Road Assembly Plant. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) curious, based on what? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Cars were not built in VIN order & 9A246399 would've been the 17 VIN sequence assigned to a "M"-code Road Runner. Does someone have a build order list? Yes I'm aware about the VIN sequence. Dave Watt, an A12 enthusiast, who did some research on my car prior to me purchasing it, provided some details about my car. From what he could tell, he believes it was the first Rallye Green A12 car built. Could he be wrong? Of course. He's pretty good though. The car has a unique history, but at the end of the day, it's M code roadrunner, just like the others built along side it.
[Re: BigDaddy440]
#2221830
12/27/16 09:04 PM
12/27/16 09:04 PM
Posts: 1,094 Georgia
Matt M
Georgia
You have to love Rallye Green
Here is my old RG A12 This was one of the most highly optioned A12's I had ever seen.
Console Auto, Buckets, PS,PB, Wood Wheel, AM/8,Tach,Rocker Molding, Reflective Stripe, Tinted Glass, Vinyl Top.
Maybe more I can't remember
