Re: 69 Road Runner spring special rallye green
[Re: badblack68]
#813856
09/25/10 02:50 PM
09/25/10 02:50 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Sorry. Records weren't kept, or exist, by color for '69 so there is no way to know the answer to either question. I'm not aware of anyone keeping track of Spring Green colored cars.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: MI_Custumz]
#813862
09/26/10 02:19 PM
09/26/10 02:19 PM
Posts: 3,380 KY USA
mopargem
KY USA
This one belongs to friend of mine, its an early production
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: MI_Custumz]
#813863
09/26/10 06:22 PM
09/26/10 06:22 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
I know of a 97 code A12 Runner by my parents house.
Is it on the A12 Registry?
[Re: Dave Watt]
#813864
09/26/10 09:21 PM
09/26/10 09:21 PM
Posts: 21,532 It's a dry heat
gtx6970
It's a dry heat
my old rallye green 1969 hemi car was 99 fender tag code.
St Louis plant btw, I have a copy of he build sheet around here somewhere
[Re: Dave Watt]
#813867
09/27/10 07:26 AM
09/27/10 07:26 AM
Posts: 5,663 Port Huron, Michigan
MI_Custumz
Yes it is. Original engine, replacement trans, 4 speed, black bench interior, black vinyl top, and I believe the light package (has fender turn signals).
[Re: MOPAR-OVERLOAD]
#813869
09/27/10 08:27 PM
09/27/10 08:27 PM
Posts: 2,473 Answering the call of the wild
ThermoQuad
I have spoken with Galen about the spring special colors. Not many cars were built in any of the colors. They were all optioned the same depending on whether it was a 4 speed or not. Most were coupes, not hardtops. It seems the 4 speed cars came with the fresh air hood and the autos did not. Full undercoating and tinted glass too. All had the performance axle package.
I am not sure if Galen knows about about a few RoadRunners painted Dodge F6 instead of Plymouth Spring Green. I did a color check today on the 999 green and now I understand why it does not match other 999 plymouth green Road Runners. It's F6 dodge. The "sp green" written inside the car probably means "special" green, not spring green. surprise surprise
Car in Question RM21H9G2296XX 1969 Roadrunner 2dr Coupe 999 Green -Car is Dodge F6 green. Spd 310 Y39 VON 9010XX Note: This is a compilation of information MoPAR B-body spring colors DODGE &. PLYMOUTH are different: 1969 Plymouth # 99 "spring? green metallic" -- PPG paint code # 44032 1969 Dodge # F6 "bright green metallic" -- PPG paint code # 2103
Spring Green was a mid year release and was coded 99, 97 or 97E depending on plant and time of year. Any non standard color, that is a color that was not specifically released for that particular make and model or cars that required special painting schemes, like a cop car, will code 99 (1969 code number).
There were some colors that received special coding such as Spring Green. Early on, it appears Spring Green was coded 99. All three plants used 99, 97 or 97E depending on the plant or time of year. Bahama Yellow coded 99 early in the year then later it codes 96. LA tended to stick with the 99 code while Lynch rd plants and ST Louis used 97 or 96 for Green and Yellow/Butterscotch.
Omaha Orange was also coded 99 before the color was changed to K2. There is at least one 99 code with a blue interior and it appears the car was blue. what color the car was actually painted is unknown. Occasionally, really odd paint codes like 16 pop up.
V2 starts to show up on Super Bees in late March and on other Dodges a little later. I've seen it on 329 SPD A12 cars.
There were not A12 specific colors, with the exception of Butterscotch on A12 Super Bees Of the 99 "normal" colors petty blue is the least common. The Saint Louis Plant used 99, 97, and 97E for Rallye Green on the tags depending on Scheduled production date . Is this 99 built march 10th considered an early SPD? STL was very hit and miss with Y codes...seeing Y39 on 69 STL car is a little unusual. Also the VON starts with 9, not common for STL 99 paint cars, so there most be some 'story' behind the car too. STL 99 paint cars did not normally receive- the special VON or Y39 code
This car in ??? is not spring Green but is a Plymouth painted F6 (F6 was released for Dodges but not for Plymouths.) That more than likely triggered the 99 paint code and probably call for the Y39 and special VON.
What is also interesting to me is the production date verses the sold date. This car was six months old before it was sold and the new models were out.
The first owner took possession of the car in September of '69? F6 Spring Green on a Plymouth is odd.
LA used special VONs for 99 paint almost all model year (very common for LA) but St. Louis did not follow the same format. There also seems to be a high percentage of 99 cars from the LA plant compared to overall production and to other plants.
Y codes and specialty VONs are also not common on STL tags. This is the first 99/Y39/9 VON tag seen by a collector of them.
Clipped from somewhere: The year 1968 was a big year for the artwork of Peter Max and the psychedelic, celluloid adventure known as Yellow Submarine. No doubt about it, the late '60s were a happening era for wild hues. Like the other car companies, Chrysler was trying to keep in step with the times, so it offered the first of its legendary High Impact Paint colors during the '69 model year. The sobriquets were memorable, the colors retina-searing, and their legacy long lasting as some HIP colors significantly add to the desirability/price of muscle Mopars.
Controversy The Fact: Code F6, Bright Green Metallic for Dodge A- and B-Bodies was first mentioned in TSB D69-23-9, dated November 27, 1968. Some sources claimed that Code 97 Rallye Green is also F6 Bright Green Metallic, but the PPG/Ditzler paint numbers are different: 2103 (F6-Bright Green Metallic) and 44032 (97-Rallye Green). The numbers from Ditzler prove that Rallye Green and Bright Green Metallic were different. Additionally, a Chrysler-issued bulletin dated January 22, 1969, listed Ditzler #43898-Rallye Green for '69 Plymouth B-Bodies (Code 99). This is the same number as the catalogued '68 Chevrolet color of Rallye Green Metallic! As it turns out, through 1968 Ditzler used a five-digit number to identify paint colors. Typically, Ditzler used the numeral "4" as a prefix for green hues. Beginning in 1969, Ditzler went to a four-digit numbering system; however, some five-digit catalog numbers were carried over. The catalog number "2103"-for F6 Bright Green Metallic-was issued during the '69 model year-and no sooner-for '69 Dodge A- and B-Bodies. The code "44032"-Code 97 Rallye Green-was the highest five digit number Ditzler issued for passenger car applications. It was assigned to give Chrysler a specific factory application number in the Ditzler paint books. Ditzler code "43898" is currently cataloged for '68-'69 Chevrolets only. The actual formula used to create Rallye Green for Plymouth in 1969 was the same formula used for the 1968 Chevrolet-Rallye Green Metallic. This was not the only time a Chrysler product wore General Motors paint-the '70 Chrysler 300-Hurst's Sauterne Gold Iridescent accents were taken from the '70 Cadillac palette. Orange (V2) and Bahama Yellow (96) followed in Dodge TSB D69-23-20. Bahama Yellow was originally meant for the "Super Bee Six Pack only." For Plymouth B-Bodies, Vitamin C Orange (K2) replaced Omaha Orange (999) on approximately February 1, 1969, as stated in TSB 69-23-18 of April 7, 1969. Depending on the circumstances, these '69 colors would be identified on the data plates as special order code 99. For example, Bahama Yellow was first catalogued for Plymouth B-Bodies in a bulletin dated January 22, 1969. The Next Decade High Impact Paint colors were cataloged for factory availability at the start of the model year for the first time in 1970. Dodge Technical Service Bulletin D70-23-6, dated April 1, 1970, stated that "Green Go and Panther Pink" had "been released." Using the Dodge nomenclature, there was Plum Crazy Metallic (FC7), Sublime (FJ5), Go Mango (EK2), Hemi Orange (EV2), Top Banana, and Panther Pink (FM3). Availability included A-, B-, and E-Bodies. The cost was $14.05 (Dodge and Plymouth), and could be included in a two-tone combination. Interestingly, HIP colors were offered on all body styles, including station wagons and 4-door sedans. Do you know of any out there? Two-tones excluded wagons and convertibles.
One Year Gone The last big year for HIP colors was 1971. For the first time, C-Bodies had cataloged availability: Plymouth (Tor-Red), Dodge (Citronyella), and Chrysler (Lemon Twist). In 1971, Lemon Twist was supposed to be meant only for Chrysler's
[Re: BigDaddy440]
#813874
09/28/10 03:23 AM
09/28/10 03:23 AM
Posts: 636 California
sixpaktoogo
California
Could you describe the visual difference between the 69 1/2 Dodge F6 Bright Green, comared to the 1969 1/2 Plymouth 97 Rally Green? Thanks.
Yes, does anyone know if there was actually a visual difference?
F6 is lighter and has a yellow tint to it. To me, a nice color on it's own, however, parked next to a correctly painted rallye green car - no contest, rallye green wins. ![](/ubbthreads/images/graemlins/Twocents.gif)
