which oil would you use? #811895
09/22/10 04:18 PM
09/22/10 04:18 PM
ontario canada
71smiley340 Offline OP
ontario canada
I am going to the change oil because the oil I use has no zinc in it. I have a 1971 Demon 340 with 6000 miles on the motor.Not sure which to use. This may have been talked about before but I am new to Moparts. Thanks Greg
Re: which oil would you use? [Re: 71smiley340] #811896
09/22/10 07:25 PM
09/22/10 07:25 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
You're gonna get many different answers.
I run 15-40 heavy duty diesel oils such as Shell Rotella T, Delo and the NAPA brand. I've had my valve covers and oil pan off a few times over the past 10 years and the engine is clean. The oil stands up very well. Zinc levels range from 1000 to 1200 ppm in todays heavy duty oils. This level of zinc is all that is needed for stock or mild builds. Racing oils are more in the 1300 ppm zinc range.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: which oil would you use? [Re: Junky] #811897
09/22/10 08:01 PM
09/22/10 08:01 PM
ontario canada
ontario canada
Thanks you I was told to make sure that the oil I used had zinc but wanted the opinion of others so
I didnt get ripped off when I go to buy th oil.
GREG
Re: which oil would you use? [Re: 71smiley340] #811898
09/22/10 08:24 PM
09/22/10 08:24 PM
IN
ahy Offline
ahy  Offline
IN
There are lots of alternatives. Diesel engine oil + STP has worked well for me on a moderatly aggressive mechanical flat tappet. The STP bumps the zinc level up a bit and may have other benefits.
Re: which oil would you use? [Re: 71smiley340] #811899
09/22/10 08:50 PM
09/22/10 08:50 PM
Locomotion Offline
Locomotion  Offline
Re: which oil would you use? [Re: 71smiley340] #811900
09/23/10 01:59 AM
09/23/10 01:59 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Here's another one to read.
Re: which oil would you use? [Re: Junky] #811901
09/23/10 05:46 AM
09/23/10 05:46 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...I was going to run the Rotella T (none synthetic) like the previous owner of my Diesel 3500 suggested & a lot on Moparts too, until I read this completely through.
http://docs.google.com/viewer?a=v&q=...o-95B2QrXOiWmNA
Re: which oil would you use? [Re: 71smiley340] #811902
09/23/10 07:27 AM
09/23/10 07:27 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I switched over to synthetic oil about 5 years ago. After looking around on this site, http://www.bobistheoilguy.com/forums/ubbthreads.php I saw that the Mobil 1 15W-50 had a very good Zinc content, so I switched to that this summer. The other versions of Mobil 1 were OK, but the 15W-50 has about 1350 PPM Zinc - higher than a lot of the diesel oils they tested. I was using the Quaker State Horsepower 10W-30, but that's only in the 900s PPM Zinc - not enough. I don't leak or burn oil, and my engine is well broken in, so the cost of synthetic over conventional isn't an issue for me as long as the synthetic has the properties I'm looking for.
The next engine I build will be roller cammed, so it won't matter so much then...
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: which oil would you use? [Re: thehemikid] #811903
09/23/10 09:00 AM
09/23/10 09:00 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Good info, but probably wasted on a lot of people. I think it's a bit outdated now.
Don't be the exception.
Re: which oil would you use? [Re: Supercuda] #811904
09/23/10 09:34 AM
09/23/10 09:34 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Valvoline 20-50 Racing Oil
Re: which oil would you use? [Re: 71smiley340] #811905
09/23/10 12:32 PM
09/23/10 12:32 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Here is one more link to get tons of oil info. Bob Is The Oil Guy web site. Read it and decide for yourself.
