8 point Roll Bar Question #811763
09/22/10 01:58 PM
09/22/10 01:58 PM
Motor City
Shaker223 Offline OP
Motor City
Rule States:
"Rear braces must be of the same diameter and wall thickness as the roll bar and intersect the roll bar at a point not more than 5" from the top of the roll bar."
My question:
Are these rear braces that extend off of the B bar allowed to have a bend in them? I'm planning on passing through the for easier access into the trunk area? I'm planning on passing through the package shelf area.
Thanks.
Re: 8 point Roll Bar Question [Re: Shaker223] #811764
09/22/10 02:25 PM
09/22/10 02:25 PM
New Jersey
Randy514 Offline
Randy514  Offline
New Jersey
When we were installing our bar, the rule-book wasn't definitive on attachment locations for the rear bars. We mounted our rear bars behind what would normally be the backseat I've seen many Camaro's certified that had the rear bars bent to fit thru the speaker cutouts. We bent our sidebars to contour the stock door-panels, and its never been an issue with tech inspection. Although our bars not certified not a 9.99 car....and at that point we'll need a cage anyway. Randy
Re: 8 point Roll Bar Question [Re: Randy514] #811765
09/22/10 02:50 PM
09/22/10 02:50 PM
Motor City
Motor City
Thank you. I found the same thing with the rule book not being definitive. The car will be in the 10's and not any faster unless I find a lot of weight to remove or a bunch more HP!
More opinions are appreciative.
Re: 8 point Roll Bar Question [Re: Shaker223] #811766
09/22/10 03:04 PM
09/22/10 03:04 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Yes - the rear braces on a roll bar are allowed to have bends. Ideally, the braces should be attached to the rear frame rails above the suspension mounting area. On a leaf spring car, that is pretty far back and is NOT a requirement. An X-Brace is also recommended, but not required till a roll cage is needed.
Also remember the seat back must be attached to the roll bar.
Scott
Re: 8 point Roll Bar Question [Re: ProStDodge] #811767
09/22/10 03:20 PM
09/22/10 03:20 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
They have no issue with mine...
-Kenny
Re: 8 point Roll Bar Question [Re: StrokerAspen] #811768
09/22/10 03:39 PM
09/22/10 03:39 PM
Motor City
Motor City
Thanks, That is what I was looking for!
Tom
Re: 8 point Roll Bar Question [Re: Shaker223] #811769
09/22/10 03:50 PM
09/22/10 03:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
His is a cage, not a roll bar The way his is done is fine for a roll bar also When your referring to a eight point bar are you sayiing the other two points are to the subframe connectors used as a lateral stabilizer off of the main hoop using them as a reinforcement bars or where are the other two bars going ? IHTMS
Re: 8 point Roll Bar Question [Re: Cab_Burge] #811770
09/22/10 04:03 PM
09/22/10 04:03 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i just got my 8pt certed at norwalk to 8.50 with the bars going thru the package shelf and connecting above the leafe spring/frame with a slight bend just at the rear window.
Re: 8 point Roll Bar Question [Re: StrokerAspen] #811771
09/22/10 06:28 PM
09/22/10 06:28 PM
ProStDodge Offline
ProStDodge  Offline
StrokerAspen - Nice bars! Now you just need to attach the seat to the cross bar to be legal.
Re: 8 point Roll Bar Question [Re: Cab_Burge] #811772
09/22/10 08:39 PM
09/22/10 08:39 PM
Motor City
Motor City
8 point like the picture above.
Thanks for the pics and advice!
Re: 8 point Roll Bar Question [Re: Shaker223] #811773
09/22/10 10:47 PM
09/22/10 10:47 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I'm trying to keep the rear bars from exiting through the back window. I'm wondering if I could start at the legally required point(say 5" down)on the main hoop and then take a sharp bend down and exit through the bottom of the rear window and then turn acutely again into the box area to attach at the frame rails. This would keep everything inside the cab and box.
Tom
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: 8 point Roll Bar Question [Re: Shaker223] #811774
09/23/10 01:18 AM
09/23/10 01:18 AM
To help clarify( I hope) the diagram of the "8 point roll bar" is actually a six point roll bar with the two (smaller diameter tubing usually) lateral stiffener to help keep the main hoop from being pushed over in a roll over crash The picture of the roll cage in the car is a ten or twelve point cage, depending on how many points are going forward that I can't see in the picture Maybe I've got it wrong and what I have always consider a six point roll bar is now a eight point roll bar
