70 B Body brake Question #810492
09/21/10 03:42 PM
09/21/10 03:42 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Picture Please...
The rear flex hose mounting bracket. This is the bracket that bolts to the floor and holds the rear flex hose where it joins the steel brake line.
Anybody have a picture of it and how it mounts?
I'm not certain I have the correct piece
CHECK OUT MY NEW WEB SITE !
Re: 70 B Body brake Question [Re: anlauto] #810493
09/21/10 06:30 PM
09/21/10 06:30 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i can't provide a pic til tomorrow,IIRC,it's about 6" long,3/4" wide got a small bend and twist in it,one hole in the end for the flex hose,other end has a hole for a bolt to go through,you should see a spot on the underside body between the muffler/tailpipe brackets that it bolts up to hope this helps,if you need a pic tomorrow am pm me
Re: 70 B Body brake Question [Re: meepmeep70] #810494
09/21/10 06:44 PM
09/21/10 06:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: 70 B Body brake Question [Re: 6bblgt] #810495
09/21/10 06:45 PM
09/21/10 06:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'70 Feb. assembled LA car w/DANA if it matters.
Re: 70 B Body brake Question [Re: 6bblgt] #810496
09/21/10 06:56 PM
09/21/10 06:56 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
WOW!good pic,i'm rather impressed with my memory
Re: 70 B Body brake Question [Re: meepmeep70] #810497
09/21/10 07:27 PM
09/21/10 07:27 PM
anlauto Offline OP
anlauto  Offline OP
That's great guys...This board and it's members are fantastic at answering questions that most people may feel are redundant....
I'm restoring a 70 B Body for the first time (in a long time) that came to me in boxes....
When I found this bracket, which now I know is correct, I thought it looked totally wrong because my mind is still in E Body mode. On an E Body the hose points to the left, not straight forward which was throwing me for a loop.
Cheers and thanks everyone AGAIN
