Re: 514 on the dyno
[Re: AndyF]
#804196
09/20/10 05:16 PM
09/20/10 05:16 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Don't know what it makes, we tweaked the dyno before we had any full runs. Dyno is only designed to handle 650 ft-lbs of torque and we exceeded that pretty quickly. Based on how it was pulling it will probably make 850 hp. I haven't figured out what to do yet. Either pay to upgrade the dyno or detune the motor.
Zippy - I think this block makes a bunch more power than the production block. I wanted to get a bunch of dyno pulls under my belt so I could get an answer on that question. This motor uses a lot of parts from my old 505 dyno mule so it is a fairly good comparison between the blocks.
That happened to us when we dynoed the 540. My engine builder had just bought a new Stuska(sp?) dyno and he had it on too low of a setting(he'd been just testing SB chevys on it..hehe). He said he almost wrecked the dyno..lol
Re: 514 on the dyno
[Re: AndyF]
#804202
09/21/10 02:01 PM
09/21/10 02:01 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Great info Andy! I guess all those parasiting drag items like the Dizz and Timing chain really come in to play....amazing HP considering the EZ exhaust ports are really (relatively) marginal when you consider the (theoretical) HP advantage of the better exhaust and the relatively same intake port in a -1 or SR Head. Speaking of intakes, why don't you slap on the old 337 and see where the HP demon really lives with that piece.
Re: 514 on the dyno
[Re: AndyF]
#804205
09/21/10 07:13 PM
09/21/10 07:13 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
I'm running a dry sump on this motor. I really like the dry sump setup. It is so much easier to dial in a dry sump and the engine oiling is a lot better. Hate to go back to a wet sump design after working with a dry sump.
Andy, why are you running breathers ?
Re: 514 on the dyno
[Re: AndyF]
#804207
09/22/10 08:00 PM
09/22/10 08:00 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
I checked out Manini and saw your adapter plate on there. I know very little about dry sumps and I am wondering how the pump mounts to the plate? Is your plate good for any pump or a specific brand? I am having a hard time visualizing the the pump to plate bracket.
1974 Roadrunner
1967 Charger
