'65 Plymouth interior paint code? #804103
09/17/10 10:26 PM
09/17/10 10:26 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Hey,
I have a '65 Satellite with two-tone gold/brown interior. I want to repaint the gold on the steel dash. The fendertag says P4Y for interior trim code.
Does that de-code into the paint color codes?
I have a DuPont paint chip sheet for '65. I took it to my local paint shop, but when they searched for paint using the codes from the two gold interior options (4658-L Med. Yellow Gold and 9088-LH Lt. Gold), they came up with GM paint colors - not any golds.
Any input to shed light on a workable paint code is appreciated.
Maybe the paint shop is just wrong?
I thought Ma Mopar used PPG paints, not DuPont?
At the paint shop I hand-matched the chip color to a fandeck of PPG metallics, but the PPG metallic flake size is too big. So I'm back to searching for the original paint code.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: '65 Plymouth interior paint code? [Re: 67SATisfaction] #804104
09/18/10 07:18 PM
09/18/10 07:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Chrysler apparently used the least expensive paint products they could get, and didn't necessarily stay with one mfr. for everything. R-M & DuPont both claimed OEM Chrysler use. That continues today with some carmakers.
A GM color may be close enough to use, especially if you tint it or use a different coarseness of metallic. For my '63 interior light blue metallic, a contemporary Toyota color was actually almost identical, just needed to kill a little of the red in the formula. The metallics used back then were quite fine, as you've noticed. The hard part is getting the low-gloss ("suede") colors & textures right.
Re: '65 Plymouth interior paint code? [Re: topside] #804105
09/18/10 11:06 PM
09/18/10 11:06 PM
Albany, NY
Albany, NY
Thanks Tops,
Your '63 is probably a lot like my '65 then: I was lucky enough to match up a good metallic brown for the upper dash. We shot a dull topcoat and it has worked out well. I'll take your advice and have a look at the paint shop's Brand (GM, Lexus, Ford, etc) chip samples and just find a current paint that has that finer metallic grain. I'll bring them my ashtray to generate matches.
Best, - Art
Re: '65 Plymouth interior paint code? [Re: 67SATisfaction] #804106
09/19/10 09:53 AM
09/19/10 09:53 AM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
I'm not sure if this helps or not. These codes are for 1965 Chryslers but I am sure they are the same for Plymouths.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
