Page 2 of 3 1 2 3
Re: open headers vs. full exhaust ? [Re: codfish] #803339
09/17/10 10:05 AM
09/17/10 10:05 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
TTI under chassis 2" headers with 3.5" collectors, 3" X-pipe kit and 3" Ultra Flows.
codfish
My brother has 2'' tri-y's with a 3'' x pipe and 3'' straight through mufflers. He has run 10.7 @ 125.5 on pump fuel with a std stroke 440 @ 3650-3700lbs. His car runs like a pig with the pipes disconected. I also have another friend with a 440 with tri-y's and its the same.
I had a 440 with 4 into 1 pipes and it responded well to open pipes. Rob.
Re: open headers vs. full exhaust ? [Re: codfish] #803340
09/17/10 10:08 AM
09/17/10 10:08 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's what I have on my Challenger, too. I don't see that particular system holding back the car's performance much, if at all.
Re: open headers vs. full exhaust ? [Re: joedust451] #803341
09/17/10 10:44 AM
09/17/10 10:44 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
So, but you also need some back-pressure, otherwize you push the torque curve way up & there goes your 60ft., so run at least 18" extentions or install cutouts (dumps as i call them)
cant this myth about backpreasure being good for a 4stroke engine just die?
you are right about adding lenght to the collectors to make a correct collector length but thats not for backpreasure that is to be able to take advantage of the pulses in the collectors to get all 4 pulses from the same bank tuned and work togheter, thats as good as i can explain it since my english is fairly crappy..
i dont think the threadstarter will gain much from open headers, maybe a tenth or so from the lost weight unless the exhaust has some problems (reduction in diameter in the bends or some other restriction) built into it in the first place
Re: open headers vs. full exhaust ? [Re: 1Fast340] #803342
09/17/10 11:22 AM
09/17/10 11:22 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I have a 3" system with H-pipe and spintech mufflers. I have cutouts in sort of a max wedge style, so the flow when they're capped isn't optimal. Every time I've done back to back tests, I've picked up 2-3 tenths, simply removing the plates.
Now, I haven't changed the jetting since the motor was dyno'd, and it was dyno'd at sea level, 70 degrees and open exhaust.
Fontana, where I usually run is 1100 ft, and DA is always 2000+, so I'm sure it's running fat anyway.
I haven't worried to much about jetting as I'm not legal for 9's and short-shift it to stay in the 10.0's anyway.
Best DA I've ever experienced was new year's day this year, 1700 ft. Went 9.92
Your results may vary...
Re: open headers vs. full exhaust ? [Re: G_bob] #803343
09/17/10 01:18 PM
09/17/10 01:18 PM
P
Paul_Fancsali Offline
P
With a poor dual system my caps are worth at least .25+ in the qtr when removed. I have lost power with full open headers when not jetted correctly. This past week I jetted up on a cooler night and gained another 1.5 mph That gain was killed when I tried to run colder again by changing thermo big mistake lost close to 2mph Oh well the testing continue's at the track next week
Re: open headers vs. full exhaust ? [Re: codfish] #803344
09/17/10 01:52 PM
09/17/10 01:52 PM
Mid-Michigan
GOREO Offline
GOREO  Offline
Mid-Michigan
codfish
Exact same setup I have also,TTI 2" headers,3" TTI x pipe and Ultra Flo's.will be making a few runs soon with the exhaust off,has run 10.95/121 with the exhaust earlier this month at Milan.
Re: open headers vs. full exhaust ? [Re: Mr.Yuck] #803345
09/17/10 01:52 PM
09/17/10 01:52 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you'll pick up 3-4 tenths
You're kidding right?
codfish
nope. Over a stockish exhaust 3 tenths easy. My old 440 coronet w/ headers and 2.5 exhaust would pick up 3-4 tenths. There's a reason most drag cars don't have exhaust. If you jet it up 2 you can pick up et. You are NOT going to lose any. I've never seen that happen. flow = HP.
He didn't say what exhaust he had on it before you made that prediction but a 3" pipes and ultraflo's is not even remotely stockish.
Re: open headers vs. full exhaust ? [Re: 1Fast340] #803346
09/17/10 01:56 PM
09/17/10 01:56 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
i dont think the threadstarter will gain much from open headers, maybe a tenth or so from the lost weight ....
My game plan is to make the first time trial with no changes. I will make a change ONLY if my time slows. Seriously, I don't think I will see much of a gain in performance, just noise level. Thanks for all the suggestions, I'll update later as to the results.
A little FYI. The time in my sig was done on a 95* day with full exhaust.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: open headers vs. full exhaust ? [Re: 68LAR] #803347
09/17/10 03:25 PM
09/17/10 03:25 PM
sweden
sshemi Offline
sshemi  Offline
sweden
higher number jets in the PRIMARIES.
Re: open headers vs. full exhaust ? [Re: 68LAR] #803348
09/17/10 10:48 PM
09/17/10 10:48 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
pull a plug - it will be leaner then with full exhaust - so i would not be surprised if there was no gain with no jet change.
Re: open headers vs. full exhaust ? UPDATE [Re: Mr.Yuck] #803349
09/18/10 11:20 PM
09/18/10 11:20 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
And the winnner is........wait for it.... wait for it..... Mr. Yuck
My car now has a new best in both ET and mph.
How's 11.28 @ 121.23 sound? The way the car ran shocked the heck out of me. I would have never thought it... By the way, I never opened the hood. The only adjustments were to tire pressure and shock settings.
Re: open headers vs. full exhaust ? UPDATE [Re: 68LAR] #803350
09/18/10 11:32 PM
09/18/10 11:32 PM
Congratulations, new best are always rewarding How much gain was that, you changed the old best on your sig. picture and my memory is horrible
Re: open headers vs. full exhaust ? UPDATE [Re: Cab_Burge] #803351
09/18/10 11:43 PM
09/18/10 11:43 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Old new best was set at the Mopar Nat's this year. 11.57 @ 118 and change. 3 tenths and 1 1/2 mph improvement. I never would have thought....
Re: open headers vs. full exhaust ? UPDATE [Re: 68LAR] #803352
09/19/10 12:27 AM
09/19/10 12:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best. Your exh must not flow to well. I plan to uncap my car next time I go to the track. But I dont think I will pick up much as it flows pretty good. Ron
Re: open headers vs. full exhaust ? [Re: 68LAR] #803353
09/19/10 12:35 AM
09/19/10 12:35 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
my 18 inch collecter extentions used on a 65 454 chevelle where over 2 tenths
11.00 to 10.76
1.39 9.85 - 137 mph
Re: open headers vs. full exhaust ? UPDATE [Re: 68LAR] #803354
09/19/10 02:15 AM
09/19/10 02:15 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Why do you say 1 1/2 mph, 118 too 121 is 3 mph
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: open headers vs. full exhaust ? UPDATE [Re: joedust451] #803355
09/19/10 03:43 AM
09/19/10 03:43 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
congrats.
Re: open headers vs. full exhaust ? UPDATE [Re: joedust451] #803356
09/19/10 09:10 AM
09/19/10 09:10 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Check the time I posted. It was after a long day at the track and I was a little tired. I guess I ran out of fingers. You are correct going off of my posted mph, but my fastest was a 120 with a 11.60et last year, so I just rounded off the difference between the two. My best ET and MPH aren't on the same pass. Kind of confusing, but that's the story of my life...
Re: open headers vs. full exhaust ? [Re: 68 HEMI GTS] #803357
09/19/10 09:59 AM
09/19/10 09:59 AM
NC
440Jim Offline
440Jim  Offline
NC
i run 4" exhaust on my car with no tail pipes, it still picks up a tenth and a 1/2 uncorked. i think every car i've ever had picks up atleast a tenth if not more.
My car (511 CID) has 4" header collectors. I did testing with open headers, 4" collector extensions, and 4" bullet mufflers. No difference from open headers to extensions with turnouts, and only 0.02 slower with the "mufflers" with turnouts. So it depends on the exhaust system, converter/torque peak, etc. etc.
Congrats to 68LAR on his new best, uncorked!
Re: open headers vs. full exhaust ? UPDATE [Re: 68LAR] #803358
09/19/10 10:34 AM
09/19/10 10:34 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
congrats.
Did you do back to back runs with and without the exhaust system?
FWIW, the weather difference between the Nats and PRP yesterday is worth about 0.20 sec.
Page 2 of 3 1 2 3
