Re: 340 cam suggestions needed
[Re: menomoniemopars]
#802546
09/23/10 03:40 PM
09/23/10 03:40 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
Keep at it Darby, It will run well. The distributor mod is a must, 15-18 initial 34/35 total should be in the ball park. With the availabe replacement pistons, I think your compression will be closer to 9-91/2:1 allthough I have Aluminum heads, I used a thinner head gasket to get compression at 10:1 the block was also deck quite a bit. I have often used the 87 octane to top off the tank after racing and street drive my junk with no ping. The only time I got pinging was before limiting advance. Good luck, see you this weekend??
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: 73swinger]
#802547
09/23/10 06:24 PM
09/23/10 06:24 PM
Posts: 69 Menomonie,wi
menomoniemopars
Menomonie,wi
How did u know it was me Chris? lol. Yes I plan on being there sunday.. did some rear suspension mods.. hoping for some traction and 11.60's!..
