header to manifolds. how much torque loss? #802523
09/15/10 10:57 PM
09/15/10 10:57 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
will my torque loss be noticable on my 440 when I switch from headers to 70 HP maniolds. Will it kill the response and power of the motor?
Re: header to manifolds. how much torque loss? [Re: BobN] #802524
09/15/10 11:16 PM
09/15/10 11:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
retune the carb for the manifolds and you should be fine. If it's a stock or mild engine the difference may be felt slightly but it won't be more than 15 or 20 ft/lbs.
- Stu Harmon
