Help with engine light code 96 intrepid
#802084
09/15/10 04:44 PM
09/15/10 04:44 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
A little background 1996 intrepid that occassionally will not shift out of low. Usually will hapeen off and on for a few days and then for weeks will work fine.
I got code number P1698 No CCP messages from TCM It said Transmission Control Module
Ok the questions What is the TCM? Where is it? And can I fix it or will need to be a professional? How much? Thanks
What was I thinking....
Re: Help with engine light code 96 intrepid
[Re: GTXKen]
#802088
09/16/10 11:22 AM
09/16/10 11:22 AM
72blubird
Minnesota
Thank you very much. My car about every 2 - 3 weeks will flat line all guages and run terrible. Then when it runs good will not shift until the guages pop back on. So I will be driving in low gear and no guages. then suddenly after time the guages pop on. Then the car runs great for a few weeks.
