1970 cuda reverse dash light wiring... #801555
09/14/10 08:19 PM
09/14/10 08:19 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
hoping someone has the wiring diagram for the dash reverse light for a 1970 cuda?? or if not a diagram does anyone know where it plugs in? thanx in advance for any help you can offer. i cant seem to find anything in the service manual.
Re: 1970 cuda reverse dash light wiring... [Re: kingkt] #801556
09/15/10 09:33 AM
09/15/10 09:33 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The wire goes through the firewall and plugs into the reverse light harness that goes to the transmission.
Re: 1970 cuda reverse dash light wiring... [Re: Snoopy] #801557
09/15/10 07:20 PM
09/15/10 07:20 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thank you for the info. does the wire from the dash light go thru the firewall with a grommet. or does it go thru the firewall harness #7? also i believe the dash light has a male and female plug in.
Re: 1970 cuda reverse dash light wiring... [Re: kingkt] #801558
09/15/10 08:48 PM
09/15/10 08:48 PM
Snoopy Offline
Snoopy  Offline
The wire goes through the firewall via a grommet.
Re: 1970 cuda reverse dash light wiring... [Re: Snoopy] #801559
09/15/10 08:53 PM
09/15/10 08:53 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
hey snoop....that is awsome!!! thank you very much. ive always wondered what all those holes are for. thanx again!!
Re: 1970 cuda reverse dash light wiring... [Re: Snoopy] #801560
09/15/10 09:01 PM
09/15/10 09:01 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
heres a picture that shows 2 ends. i understand the plastic end goes to the trans but where does the female end go thank you
