451 Stroker Build Questions
#800742
09/13/10 11:34 PM
09/13/10 11:34 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I tried to post this today but it seems to have disappeared.
I'm building a 451 stroker. What I have now is:
400 block MP 440 stroker crank (400 journal size) 906 heads with roller rockers, 2.02/1.81 valves, not sure what the springs are rated for. stock 440 rods TTi 1 7/8 ceramic coated headers 7 quart pan
I need help on a good intake, carb, cam, lifters, push rods set up. Also I would like to know if the rods are okay or if I should spend coin on some H beams and how to shop for pistons.
I did a search and couldn't find any 451 recipes. This is a pump gas street car with 3.91 SG and 4 speed.
Thanks!
I’m listening.
Re: 451 Stroker Build Questions
[Re: Big Bad Bee]
#800743
09/13/10 11:39 PM
09/13/10 11:39 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
KB pistons, make sure the rods are sized properly and round with good bolts. Balance the crank. RPM intake 950HP carb Comp 295HL cam for hyd. What rockers and ratio? I would look and some mild port work....
Brian Hafliger
[Re: Brian Hafliger]
#800744
09/14/10 01:18 AM
09/14/10 01:18 AM
Big Bad Bee
Spokane Valley, WA
I've got to take a look at the rockers. They are off the heads right now. The heads have been ported and polished. Not sure how aggressively but whoever blended the bowls did a very clean job. Thanks for the tip on the bits and pieces.
I’m listening.
[Re: Big Bad Bee]
#800745
09/14/10 10:05 AM
09/14/10 10:05 AM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
Thanks!
have you tried to fit that crank in the block yet ? I bought one of those from MP and all they did was take the Hemi replacement crank and and have it sized with low deck mains. When I went to check clearance in the block the counterweights sat on the bottom of the bores , crank didn't even sit in the bearing saddles. The OD of the counterweights is roughly 7.500 , I had them cut down to7.200 only needed a couple small holes to balance for 2300ish bobweight. If you notch the bores and use the crank as delivered you'll end up turning the counterweights into swiss cheese to get it down in weight as they are sized for a HEMI bobweight.
Otherwise I'd think long and hard about getting a better rod than stock LY's and if you are going to use open chamber iron heads you should build for quench , which is alot of work to do it correctly, if you want a pump gas friendly moder, will require a step head piston with a D dish.
That's How I would and am currently doing it , it's a little more expensive but the end results are worth it .
[Re: Big Bad Bee]
#800746
09/14/10 12:52 PM
09/14/10 12:52 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
If you have access to a good crankshaft grinding company you can have the crankshaft offset ground to BB chevy rod journal sizes and make the stroke grow to 3.910 or 3.900, depending on if the crank is stock Mopar rod journal size now or if it is ground down to .010 under. That allows you to buy a decent forged piston from KB and use a 6.585 long BB Chevy style H beam rod for a decent price This combination will make the motor 464 to 471 C.I. depending on the bore size, this was a common way to stroke a Mopar before the price of stroker crankshafts came down. The increase in stroke really makes the motor wake and act like a big dog It ends up making a lot more torque as well HP
[Re: JohnRR]
#800747
09/14/10 01:48 PM
09/14/10 01:48 PM
Big Bad Bee
Spokane Valley, WA
Thanks!
John,
No, I haven't checked that crank yet but you can bet I will this weekend. I was wondering why the heck MP would sell a Hemi replacement crank as a 400 based stroker crank that doesn't fit the application... Then I remember that we are talking about MP... Hopefully MP corrected the gaff before my crank was purchased.
If it's okay, I would like to PM ya regarding the pistons and rods for some more details. What cam/intake/carb are you using? I'll be in the garage tonight checking on my rockers and that crank.
Cab, I've read through a couple blogs and articals describing the BBC rod deal so I understand at least in theory. If my crank is like John's was, I will be taking it in to have the bob weights shaved and give your idea serious consideration. The guy that's helping me build the motor actually owns a shop that specializes in crank turning, so with the cheaper rods and slugs and low cost shop time, I may come out better all the way around if the crank needs work.
I’m listening.
[Re: Big Bad Bee]
#800748
09/14/10 03:12 PM
09/14/10 03:12 PM
JohnRR
U.S.S.A.
send me an email thru the link in my bio , my pm box is too full ..
[Re: Big Bad Bee]
#800749
09/14/10 04:25 PM
09/14/10 04:25 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
MPs method of correcting the RB sized counterweights was to stop selling that crankshaft. Stop selling the part, problem solved. Just being honest. Plan on either putting it in a lathe or working it by hand.
I'm using a reworked OE crank in mine, which I reshaped the counterweights using a homemade template + a series of grinding and polishing up the counterweights. It was an 80 dollar swap meet crankshaft that I paid another 90 dollars for machine work, 25 to mag, and the rest I did myself. I wouldn't really recommend anyone else do that, but I was a broke musician at the time and dont mind doing tedious stuff like that.
I would have to have some idea what the goals are, and what the budget is to really make any recommendations on the combo, how to buy pistons, what to look for etc.
My own goals for my 451 was ballpark 600HP flywheel and high 10s. I've got the first one (499rwhp), and hope to make it to the second goal this year. It's also a pump gas street car that started with 3.91s, but now has 4.10s, and is driven for hours at a stretch on the street...
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#800750
09/15/10 01:54 AM
09/15/10 01:54 AM
Big Bad Bee
Spokane Valley, WA
Thanks Zippy. I went to the 451 because I got the crank and block with the car and the previous owner turned me on to this engine build. I also have a 440 block but only a cast crank for that. My goal is to have a car with A/C and a decent lope at idle. Something that doesn't mind 800 RPM an MP 509 hydraulic cam is too hot. I am shooting for 550 hp and would love 600. The car will likely see eddy heads at some point. It will see the track a couple times a summer just for fun and to see what she'll do.
I am on a low budget but I want the engine to last, so I will spend money where it really counts.
I’m listening.
[Re: Big Bad Bee]
#800751
09/15/10 10:36 AM
09/15/10 10:36 AM
ZIPPY
S.E. Michigan
Aha. Yes a 509 is too hot, I wouldn't use it unless you had maybe another 30-40 CI to fall back on.
If it's going to get eddy heads, then something close in specs of an MP .528 and an RPM intake will do what you're looking for. If you'd rather have a hydraulic, be careful with lobe separation and try to find something in the 112-115 range...but the solid will almost always run better all the way around.
For pistons you're looking for 1.32 compression height and 4.375 bore, flat top with valve reliefs. When the machine work is done you will want anywhere from zero deck to around .008" in the hole which will give you around 10.5 to 10.75:1 with most off the shelf composition gaskets. You won't really "need" forged pistons for this unless you think you might get greedy for more power later on, but forged is not much more than hyper/cast, and it's a worthwhile upgrade for later on. It also adds value to the engine in case you decide to sell it later.
It will live forever with properly prepped LY or 6 pack rods....but once you're done with rod prep, you're usually $200 away from aftermarket H beams, so I'd recommend a budget H beam rod like Eagle, or something similar.
The above build is tried and true, a local buddy has it in an E body with a 6 pack intake and TTI headers and he has a blast with it....AndyF also wrote a mag article about the same build some time back....it flat out works.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#800754
09/15/10 11:55 AM
09/15/10 11:55 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
okay, If you're looking for a mild build that will run AC and idle nicely at 800 RPM, then really, why are we talking about spending money to hack into his MP crank, if he already has a 440 block sitting there???? You've said you have an MP 3.75 crank..... And you've said that you have a 440 block sitting there, but only a cast crank for that. The MP crank IS a forged 440 crank (426 Hemi and 440 use the same crank)! I know this started as a 451 build thread, and trust me, I love the 451 combo, but..... I'm going to suggest that using the MP crank in the 440 block is his best option.
[Re: StealthWedge67]
#800755
09/15/10 12:14 PM
09/15/10 12:14 PM
ZIPPY
S.E. Michigan
His crank already has 2 and 5/8 mains, which will give him 1/8" oil clearance if installed in a 440 block.
400 mains 2 and 5/8 440 mains 2 and 3/4
Not gonna work
Rich H.
Esse Quam Videri
[Re: Big Bad Bee]
#800759
09/15/10 01:11 PM
09/15/10 01:11 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I don't know much about the MP crank, but if you have to have the counterweights cut down, I would have the crank offset ground to 3.90" using the 2.2"BBC rod size and use the aftermarket H or I beam rods with the 0.990" pin, then you can use the KB/ICON forged pistons which are less than $500/set. When I built my 451 20 years ago with the reconditioned stock 440 rods, I knew the rods were the weak link in the short block, and I was lucky that they never caused a problem, but there is a good selection of stronger aftermarket rods that are very affordable, and replacing the rods after the engine is built is not easy because of ballancing the engine.
Also the extra displacement from the 3.90" stroke will help you get to 500+ HP while still having a decent idle. The 3.90" stroke, KB/ICON piston setup uses the shorter 6.535" connecting rods with 2.20/1.90" bearing/pin sizes.
If you decide to stay with the stock rods with the 1.094" piston pin KB only lists the #280 piston which is a step head hypereutetic piston. This would work with open chamber heads, but setting the quench is a big pain, and if you install closed chamber heads later you would have to either replace the pistons or mill the step off and re-ballance the engine again. If you want Forged pistons with the 1.094" pin Ross pistons is probbably the least expensive at around $600/set for the #99494 flat tops, otherwise you are looking at over $100 per piston. This is my reasoning for going with aftermarket rods, they pretty much pay for themselves in how much you save on the cost of the pistons, not to mention the wider selection of rod bearings in the 2.20" size. You may also want to use the 4.375" bore size because I think piston rings are cheaper / more avaliable in that bore size.
My old 451 used a M1 4150 style intake and 1,000 cfm Holley HP carb which worked good in my combination, but I was running a solid roller cam, and would shift at about 6,500 RPM.
For a more street type setup, the performer RPM would be good. The 950 or 1,000 cfm HP carbs are good, but have no choke/fast idle so you may have to sit in the car bliping the throttle till the engine warms up. The regular holley 4150 series 850 cfm carb has a choke if you drive on cold days, but it will cost you a little power.
[Re: 451Mopar]
#800760
09/15/10 01:36 PM
09/15/10 01:36 PM
Posts: 9,870 Weddington, N.C.
Streetwize
Weddington, N.C.
I'm a big fan of the 451, was building them years before they were 'flavor of the month'
I'm a little different in that I prefer the the shorter 6.36" 383 rods when using OEM because (if for no other reason) a beam with a shorter center to center and the same cross section and material is just a little stronger and the shorter rod 451 motors (to me) are just a little more responsive all else being equal.
Perfromer RPM or Holley SD, tweaked 906's and a good Hydraulic performance cam like the Lunati 235/245 @.050 or the Crower 231/240 @.050 along with a flat top 10:1 piston and a 750-800DP (with iron heads, go a bit larger with aftermarket Eddies/stealths) should run very well for you. Don't over think it because a 451 is really no more than a 'dimensionally optimized 440'; so any sound proven combo for a 440 works equally as well, if not just a hair better (lower overall bobweight and total installed weight) in a low deck 451.
With a 4 speed and 3.91's I might step up the cam to the Comp XE 241/247 but in a 108 intead of 106 and only if you're running aftermarket rockers, but I wouldn't run that cam with the oem stramped steel rockers.
#800761
09/15/10 02:53 PM
09/15/10 02:53 PM
JohnRR
U.S.S.A.
Not gonna work
I thought we had already established that the crank was a Hemi Crank, would have to be machined to fit into a B-Block. ???
No , he was warned as to what the crank is, I bought one a number of years ago and that's the same crank. Plus I don't think they are 4340 material, I think it was a 5140 crank, basically a stock replacement crank, Zippy will correct me if I'm wrong.
