340 Replacement Block #800456
09/13/10 07:53 PM
09/13/10 07:53 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
How much power can the 340 replacement, non Siamese block handle? I'm looking to put a procharger on one, and was concerned about the durability.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: 340 Replacement Block [Re: Cudahlr] #800457
09/13/10 07:59 PM
09/13/10 07:59 PM
ohio
all spooled up Offline
ohio
theres a guy on here turbocuda 1100hp say no more
Re: 340 Replacement Block [Re: all spooled up] #800458
09/13/10 09:10 PM
09/13/10 09:10 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
That's me....the 340 replacement block is a tall deck non siamese R-3 block...about 50 lbs heavier than a standard 340 block....thicker decks, filled pan rails, 4- bolt mains, beefier cylinder walls....very beefy piece.
At about 1100 hp had a very slight bit of capwalk but was using the stock mopar bolts...switched out to ARP main studs now...hope this helps.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 340 Replacement Block [Re: Cudahlr] #800459
09/13/10 11:44 PM
09/13/10 11:44 PM
SoCal
Brian Hafliger Offline
SoCal
A bad tune can hurt anything!! Do you already have the block?
Brian Hafliger
Re: 340 Replacement Block [Re: Brian Hafliger] #800460
09/14/10 06:28 PM
09/14/10 06:28 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
No I don't have the block, a friend has changed directions and offered it at a great price.
Re: 340 Replacement Block [Re: Cudahlr] #800461
09/14/10 07:10 PM
09/14/10 07:10 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
If its a new block make sure you have your machinist check the cam bearing bores and the lifter bores before it leaves after decking, boring, honing ect. I could not get the cam or lifters in mine without a lot of honing before assembly. Pain in the azz. Just my -Randy
