Re: Anyone seen factory '70 Superbee red grill stripes?
[Re: nutso suave]
#80044
06/26/08 03:40 PM
06/26/08 03:40 PM
Posts: 627 My hovercraft is full of eels
DaveKanofsky
If you mean the vertical bars of the grille, I've never heard of that.
The dealer brochure shows the grilles with the inner ring of the grille painted red, although it seems like none were actually built that way.
Hope this helps.
MOPARS ONLY! '69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't Chaplain, Racers For Christ ( http://teamrfc.org/) John 3:17
[Re: nutso suave]
#80048
06/26/08 09:51 PM
06/26/08 09:51 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Can you get a part number off the grille? It would be interesting to see the application.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: nutso suave]
#80055
08/17/08 09:44 PM
08/17/08 09:44 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I've never seen anything like that, and I've seen quite a few of those old grills.
Mike
1969 Dodge Dart Swinger
[Re: DaveKanofsky]
#80056
08/17/08 10:58 PM
08/17/08 10:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hope this helps.
I don't buy the vertical lines.......
But my brother in-laws 70 Superbee did have the inner "grille rings" painted red,......the car was red w/ black top/ interior.....383 4spd, powerdome hood,......very beat, but very original! never been restored,....or repaired for that matter,.....I ended up, buying it, and parting it out,......so I recall many of it's parts or details........
[Re: nutso suave]
#80058
08/18/08 12:58 AM
08/18/08 12:58 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
they look like they are red in the ad i attached...
The vertical grille bars?
Yes, it is possible it's original, but it's also possible it's been swapped from a 500, too.
Sometimes the part number is the same for the base grille, and the paint details or specific trim is/are added later.
Who cares, it looks cool and you have a print ad to back it up. Just like the '71 Challenger T/A owners.
You'll probably never get a definite answer one way or the other.
[Re: In_The_Pink]
#80059
08/18/08 01:08 AM
08/18/08 01:08 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Who cares, it look cool and you have a print ad to back it up. Just like the '71 Challenger T/A owners. You'll probably never get a definite answer one way or the other. [/quote} .... .....you do know Galen Goiver has 2 vins on record of 71 T/A's........
[Re: nutso suave]
#80061
08/18/08 01:33 AM
08/18/08 01:33 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Not to change the year but again red in color
I always found this interesting and without an explanation from anyone - I have seen more then a few of these over the years - The horizontal stripe down the middle of 71 charger concealed headlamps - Most are black some gray/silver in color but - Trust me when i say my 71 Superbee concealed headlamps have never been restored - Yes there coded on the broadcast sheet/fender tag but the red in color - Anyways
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
