440 blower intake needed #800269
09/13/10 04:19 PM
09/13/10 04:19 PM
California
hemibill Offline OP
hemibill  Offline OP
California
I am just starting to assemble parts for a 440 blower motor for my next project. I am looking for an intake that sits the 6-71 blower as low as possible but still has enough room on the intake ports to add fuel injector bungs. Has anyone gone this route before? Any one brand intake better than another?
Many thanks!
BILL
Stop making excuses... start making SOLUTIONS!
Re: 440 blower intake needed [Re: hemibill] #800270
09/13/10 06:16 PM
09/13/10 06:16 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
did you look at the INDY intake?i think you use spacers for an RB engine.what other choices are there other than having 1 made and a custom used.
http://www.indyheads.com/images/news11.pdf
Re: 440 blower intake needed [Re: blownzoom440] #800271
09/14/10 04:04 AM
09/14/10 04:04 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The BDS intake is pretty low, can't make it much lower than that.
Plynouth VIP '67 TT IC EFI
Re: 440 blower intake needed [Re: jyrki] #800272
09/14/10 07:13 AM
09/14/10 07:13 AM
ELYRIA,OH
ELYRIA,OH
ya but i dont see any way to have injector bungs in it unless it is mechanical inj where the smaller hose can fit thru a hole in the side wall of the intake and then into the port.
Re: 440 blower intake needed [Re: blownzoom440] #800273
09/14/10 03:37 PM
09/14/10 03:37 PM
California
hemibill Offline OP
hemibill  Offline OP
California
Thanks for the link. VERY interesting!
BILL
Re: 440 blower intake needed [Re: hemibill] #800274
09/14/10 07:42 PM
09/14/10 07:42 PM
ELYRIA,OH
ELYRIA,OH
dfi has been tough for blown engine tuners.i hope iy can work for you.are you going FI for more driver view?
Re: 440 blower intake needed [Re: blownzoom440] #800275
09/14/10 10:11 PM
09/14/10 10:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why has it been hard for blower guys? Is there something odd going on in the intake that is different from what turbo guys see?
- Stu Harmon
Re: 440 blower intake needed [Re: feets] #800276
09/14/10 10:22 PM
09/14/10 10:22 PM
ELYRIA,OH
ELYRIA,OH
i have only read that it is the tip in from part throttle too rich or something.if BS3 has a handle on it that would be cool.
Re: 440 blower intake needed [Re: blownzoom440] #800277
09/14/10 10:46 PM
09/14/10 10:46 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Re: 440 blower intake needed [Re: hemibill] #800278
09/15/10 03:53 PM
09/15/10 03:53 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
check out my add here for a complete V671 blower setup
that could be setup to go EFI very easily
about half way down the page..
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Re: 440 blower intake needed [Re: blownzoom440] #800279
09/23/10 07:10 PM
09/23/10 07:10 PM
California
hemibill Offline OP
hemibill  Offline OP
California
I wanted to go with port fuel injection so that I would not have carbs sticking through the hood. As much as I like that look, I am hoping to NOT cut a perfect '70 Road Runner (power bulge) hood. Stock (sleeper) look is what I'm hoping for (even if I have to lower the engine slightly to make it all fit).
BILL
Re: 440 blower intake needed [Re: hemibill] #800280
09/23/10 07:16 PM
09/23/10 07:16 PM
ELYRIA,OH
ELYRIA,OH
will you put fuel thru the blower rotors or have the blower set for street use and about .010 case to rotor gap?
Re: 440 blower intake needed [Re: blownzoom440] #800281
10/04/10 04:22 PM
10/04/10 04:22 PM
California
hemibill Offline OP
hemibill  Offline OP
California
No.
BILL
Re: 440 blower intake needed [Re: hemibill] #800282
10/05/10 07:23 PM
10/05/10 07:23 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
BILL
You will still need to have some type of throttle body on the top of the blower, so, carbs or not, I don't think you have a prayer of getting a 6-71 to sit below the hood.
Even with no blower, its going to be difficult to keep my EFI throttle body under the hood (yeah, a 440 intake on a hemi block doesn't fit well LOL.)
Your best chance for "blown sleeper" (flat hood) is to go with a ProCharger system.
Re: 440 blower intake needed [Re: ProStDodge] #800283
10/05/10 07:55 PM
10/05/10 07:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you're going with a Procharger and EFI you might as well do a front feeding intake and keep it below a stock hood.
- Stu Harmon
Re: 440 blower intake needed [Re: feets] #800284
10/06/10 01:44 PM
10/06/10 01:44 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
another way to keep it low is to use a twinscrew blower with the inlet in the back of the case ontop of a low intakemanifold
http://www.roadkillracing.se/index.html
this is one of the few dragcars i know about using a twinscrew you can see some pics there of the car check them out and see what you think,also this thing has a very tall singleplane intakemanifold with a tall adaptor for the blower ontop of it so a lower intakemanifold made with height in mind will make it alot lower
here is some more pics of how tall the intake is and you can probably gues how much lower it can get
http://www.chevelleforum.se/viewtopic.php?f=9&t=81&start=130
btw nomather what brand of car, that is one bad car and some very nice guys in that team
