8.75 BACK BRACE BENT SHOCKS
#799490
09/12/10 08:20 PM
09/12/10 08:20 PM
Posts: 75 southwest pa
bodyworks racing
southwest pa
bent my shocks at xenia back brace hit the shock body hard enough to bend the rod could my mexican ss springs be junk after only 158 passes or do i have other grimlins
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: 8.75 BACK BRACE BENT SHOCKS
[Re: Randy..]
#799492
09/12/10 09:05 PM
09/12/10 09:05 PM
bodyworks racing
southwest pa
thanks randy the shocks are c/e and with the car at static height when i pull them off at the bottom they extend 3 in beyond the shock stud i think they bent from axle wind up because the top of the brace hit the shock body
[Re: jcc]
#799494
09/13/10 04:02 PM
09/13/10 04:02 PM
bodyworks racing
southwest pa
good picture jcc last nite and today we made the shock studs longer and spun up some spacers to give us clearance replaced the springs and shocks should be good for norwalk then i will set car at static height and mark the back brace and cut it like yours nice touch with the holes to lighten the brace thanks again
[Re: tubtar]
#799498
09/13/10 09:12 PM
09/13/10 09:12 PM
Posts: 1,443 Maryland
Dads426
Maryland
Had the same problem on our 64 Plymouth. They were too close for comfort with the back braced 8-3/4". I ended up drilling a hole in the trunk floor in line with the original shock holes, reinforced the trunk floor and ran a long bolt through all three holes (near the sender wire on the left and under the spare tire hold-down on the right). The shocks were installed on the section between the trunk floor and the rear shock mount. Had plenty of room and never had a problem with them contacting the rear. BTW, we ran Mancini SS springs w/o a snubber.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 3ddart]
#799501
09/14/10 10:07 AM
09/14/10 10:07 AM
bodyworks racing
southwest pa
thanks dave i will give them a shout and see what they have to say!
