Auto column top 3 parts removal #799237
09/12/10 01:13 PM
09/12/10 01:13 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
I am going from an auto column to standard,
I want to change out the top 3 parts to remove the auto shifter and indicator.
I have got past the turn signal switch and the snap ring, looks like a bearing in there will this pry off or do I need a puller???
Anything else past this part?
Thanks 70 Dart
Re: Auto column top 3 parts removal [Re: DAMOPARS] #799238
09/12/10 03:56 PM
09/12/10 03:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Not sure on A body, but on my car once I got the snap rings off the column covers pulled off by hand and I dropped my new parts on.
Re: Auto column top 3 parts removal [Re: DaytonaTurbo] #799239
09/13/10 03:47 AM
09/13/10 03:47 AM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
I had to coax mine a bit with a mallet and a small pry bar. Sometimes they're a little sticky. Be careful not to gouge the collar. I wrapped some electrical tape around the pry bar to cushion it.
