Aluminum W2 heads #799160
09/12/10 10:58 AM
09/12/10 10:58 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
I have a set of rectangular port aluminum heads. They are about to drive me crazy with issues.
1. I had to have the water jacket ceramic coated because the were seepin water into the intake ports.
2. I had to put helicoils in a couple of intake bolt holes and a couple of exhaust port holes.
3. Now the bolt on the rigt side middle port is stripped.
I met Herb McCandless last year and he told me that rectangular port W2's were made by Diamond not Batten. Stamped on the head is RAM with a date. I was told that RAM stood for Richardson Auto Machine back east.
I am ready to pull the heads and put heli coils in every bolt hole including the rocker stands. It just seems that the aluminum from the eighties is not anywhere close to what is availabvle today.
Any info/opnions would be appreciated.
Re: Aluminum W2 heads [Re: babarracuda] #799161
09/12/10 11:06 AM
09/12/10 11:06 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wow that's a bunch of issues. When you say rectangular port, are you saying the intake ports are rectangular?
The only heads I know of right now that are the closest to W2's are the Indy 360-2's
Re: Aluminum W2 heads [Re: Dragula] #799162
09/12/10 11:21 AM
09/12/10 11:21 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Batten made square raised port aluminum w2's I just put a set on a buddies stock stroke 360. They also had issues. However they are hanging in there right now . They work pretty good-consistant 11.o's at 122 in a 1966 satellite.
Re: Aluminum W2 heads [Re: babarracuda] #799163
09/12/10 11:28 AM
09/12/10 11:28 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It seems to me Batten did make a rectangle port version. It's not uncommon for
Batten or other oval port heads to be converted to rectangle port, I'd say your's
are not Battens (picture) as they had core plugs in the ends of them.
Good luck.
Re: Aluminum W2 heads [Re: S/ST 3040] #799164
09/12/10 11:35 AM
09/12/10 11:35 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
ours had core plugs and were not oval modified.
Re: Aluminum W2 heads [Re: B1MAXX] #799165
09/12/10 11:44 AM
09/12/10 11:44 AM
S/ST 3040 Offline
S/ST 3040  Offline
I meant HIS picture shows no core plugs. The Battens I have pictured do.
Re: Aluminum W2 heads [Re: babarracuda] #799166
09/12/10 12:05 PM
09/12/10 12:05 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
go to shadydellspeedshop.com there either diamond or batten..
Re: Aluminum W2 heads [Re: fishy340] #799167
09/12/10 12:23 PM
09/12/10 12:23 PM
Finland
mafo Offline
mafo  Offline
Finland
It s just something you have to live with...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Aluminum W2 heads [Re: babarracuda] #799168
09/12/10 03:39 PM
09/12/10 03:39 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Those are without a doubt Diamond heads. The end of them is a dead give away.
ALL Battens have freeze/core plugs in the ends of them, Rectangle, oval, does not matter. They made them in both port configurations....
Yes the aluminum is soft & porous... Heli coil in all bolt holes would not be a bad idea & use anti-seize on any that you don't have helicoiled including spark plugs.
RAM is probably an old Bill Richardson stamping.
Re: Aluminum W2 heads [Re: RyanJ] #799169
09/12/10 07:09 PM
09/12/10 07:09 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Are the rectangular heads better than the oval port??
Re: Aluminum W2 heads [Re: MIKES_DUSTER] #799170
09/12/10 07:37 PM
09/12/10 07:37 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Only if your motor needs more cross section & slower port speed.
The Diamond rectangle port is basically just same as INDY 360-1 rectangle port, except little bigger everywhere.
The Batten rectangle port IS the 360-1 port because, well ICH bought the Batten tooling when they went Bankrupt in late 90's. Only thing they really changed was the intake valve guide boss.
Re: Aluminum W2 heads [Re: RyanJ] #799171
09/12/10 07:48 PM
09/12/10 07:48 PM
Thanks Ryan!!! I have a set of W-2's that are oval port but have the tops of intake runners are rectangled. Is that for better flow??
Re: Aluminum W2 heads [Re: MIKES_DUSTER] #799172
09/12/10 07:53 PM
09/12/10 07:53 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
That's old school... I would'nt do it but have seen lots of them done like that back in the day.
Re: Aluminum W2 heads [Re: RyanJ] #799173
09/12/10 09:58 PM
09/12/10 09:58 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I had a set of Battens before my Brodix. They were HUGE, and since the car is street driven more than raced, I opted for a smaller port and port volume. The battens I had looked identical to the stock mopar casting, and Mine were origional rectangle port heads, and were opened up farther. I didnt know the flow number were huge when I bought them. The guy told me high 280s, and when I go them they flowed a tad over 320 @ 700 lift, so they wouldnt do me any good. I didnt want to buzz a street engie like that all day to make the power.
But they were NICE heads. I made a billet vc rail for them because the origional vc rail was rough, and Im sure they would have leaked.
Kasey
Re: Aluminum W2 heads [Re: Moparnut426] #799174
09/13/10 10:16 AM
09/13/10 10:16 AM
Carson City, NV
Carson City, NV
My heads have such large ports that it was a pig with a 284/.528 purple shaft at 4000'. I put a Weiand dual plane and a smaller cam and it came alive. After I helicoil all the bolt holes in the heads, maybe I can just drive it and make a few passes on one of my good days.
Re: Aluminum W2 heads [Re: babarracuda] #799175
09/13/10 01:04 PM
09/13/10 01:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
the Battens I saw had a very small square port. I mean square, the floor of the runner doesn't start untill about an inch off the deck and the roof of the runner is maybe .060 from the valve cover rail. Was 195cc as I recall.
Re: Aluminum W2 heads [Re: B1MAXX] #799176
09/13/10 02:25 PM
09/13/10 02:25 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Picture of my rectangular port Batten W2's. I know it's a lousy picture but you can see the freeze plugs in the end of the head.
