Battery cable size question???
#798413
09/11/10 12:04 AM
09/11/10 12:04 AM
Posts: 2,052 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
After the cranking problems that I had last sunday at Mopar Thunder, I've decided to do what should have been done long ago-rewire this car to todays standards. First, a little back ground. '72 E body barracuda, batteries (2 red top optimas) in the trunk, no alt. 440 +.030", 13.6:1 compression, race gas. The pos cable went from each battery to master disconnect, to the starter. from the starter to the starter relay, to the rest of the car via factory fusible link, using factory ign switch. Ground from each battery went to frame rails under the battery. Never had a problem with this set up except a battery went bad last year, (replaced under battery warranty) even running 2 classes at Bristol (going to finals in both) with a total of 17 passes in 10 hours, charging in between early rounds. Then changes were made. Gear drive, crank trigger, locked out timing at 36*, MSD pro power coil. Had run this set up for 4 races with a total of 28 passes until last weekend (mopar thunder). Fri we made 5 passes, charging between rounds. Sat ran 2 classes, 13 passes no problems. Sunday, take car out of the trailer (charged batteries over nite) low voltage caused starter kick back. Nothing but trouble from that point forward. 6 passes, had to be jump started 3 of them. The questions; I'm pulling pos and neg cables from batteries to starter, with grounds also to frame. Will a #2 gauge cable be large enough? Will putting ignition switch seperate from start switch be ok with out a start retard? (start spinning engine, then light the fire). I'm also going to remove factory starter switch, will 14 gauge wire be large enough for every thing else? (except relay to starter, 10 gauge) Am I missing anything else? I will appriceate any guidance you guys can give me. Sorry this turned out so long, but this HAS to get fixed. Thanks again, Brian Dunnigan
Re: Battery cable size question???
[Re: Quicktree]
#798415
09/11/10 08:08 AM
09/11/10 08:08 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I agree you lose the starter retard.One thing to add. make sure you run a ground cable from the battery to the motor. In my cars I run a ground cable from the battery forward to a stud in the roll cage usually at the A bar near the dash. From there to both heads. Yes both . An old timer said it's the added short point for insuring a good ground for the plugs. from the dash stud ground is also where I run my MSD ground.
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#798416
09/11/10 08:53 AM
09/11/10 08:53 AM
Posts: 976 ontario canada
mac56
ontario canada
I agree with Fred. Run a ground directly to the block from the batteries. I have had the same problem on 2 different pull tractors. Start retards, bigger cable, separate ignition switch from starter switch, 3 batteries. Then put a ground to the block then the chassis from there for the rest of the vehicle. Now it wheels over like a tornado. Then witnessed the guy that bought my other tractor struggle 2 weekends ago and told him to change the grounding and then last weekend after doing this it also started with no effort. Give it a try. Very cheap fix if it works for you too.
[Re: mac56]
#798417
09/11/10 09:31 AM
09/11/10 09:31 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
My battery is in the front and I run 1 gauge cables.My 12.5 440 cranks like a /6 with the mini starter.Rocky
Chrysler Firepower
[Re: '72CudaRacer]
#798419
09/11/10 10:35 AM
09/11/10 10:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run 1 battery... 1 ground.. it goes to a stud welded to the chassis same at the front... I run a alt... I did have a field wire fall off the alt last weekend and due to that it was the FIRST time in 6 years I have ever had a charger on my car and that includes the winter months... from what some are saying maybe I should run maybe 10 grounds... come on guys... 1 GOOD ground is all you need... keep them clean and a big enough wire size... electricity still works the same as it always has... it goes to the least resistance
[Re: '72CudaRacer]
#798421
09/11/10 03:50 PM
09/11/10 03:50 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
As Quicktree mentioned,get a good alternator. I ran my car for a few years without one and now have one,best thing I did to the car.
[Re: oldtimer5151]
#798424
09/12/10 12:41 PM
09/12/10 12:41 PM
Posts: 22,722 Bitopia
jcc
Bitopia
Go to welding shop and get small welding cable and run from disconnect switch to starter. The multi-fine strand wire has the least reistance and delivers the most power to the starter.
Sorry, I disagree. Copper welding cable's main feature is it's flexible, and tough. IN DC, multi strands offer no benefits. In similiar materials, resistance is all about cross-sectional area of the cable, times lenght of the cable, and if you want to be picky, temperature.
[Re: jcc]
#798425
09/12/10 01:22 PM
09/12/10 01:22 PM
Posts: 4,210 New York
polyspheric
New York
X2 - flexible is a convenience, nothing to do with how much current it transmits.
Steel (chassis) is an acceptable ground, provided that the X-sectional area is larger than the cable you're not using, and that all connectors have a contact surface at least as large. A 5/16-18 bolt into the firewall isn't enough.
but... why would anyone use smaller than 00 cable for a long run?
Be wary of buying cable at a flea market, or out of the trunk of a car - it may still belong to the utility company.
Boffin Emeritus
[Re: DoubleD]
#798427
09/12/10 08:08 PM
09/12/10 08:08 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Let me throw my in here about size and application on wire sizes in D.C circuits, to little of a wire will increase the resistance during large current requirements (starting the motor), it forces more current through the smaller cable causing heat in the wires which increases the resistance To large of a cable size is not usually a problem in cars, especially race cars Proper grounding is As already said use two grounds in the back and the same size cable (# 1,0 or 00, not #4 or #2 ) as the hot feed for the ground to the front and attach it to the motor with a large wire size eyelet, I use a 7/16 eyelet soddiered(SP?) onto my cables and attach them to the 7/16 transmission bolts to the block for the ground and directly to the starter lug on the starter for the main feed from the batterys. I use a #2 cable for the main feed to the rest of the circuits on the car from the starter One of the things I have learned on low voltage circuits is to use the largest wire size needed to avoid any voltage drop at the far end being tested You will always see a voltage drop at the starter motor when it is spinning the motor over, you shouldn't see any voltage drop at the starter when it is not being used (or anything else drawing curent)versus checking the voltage at the batteries BTW, on digital VOM meters don't worry about a change of .01 volt differences, do worry if it is more than that there shuold be very minimal voltage drop, less than .01 volts, through the main battery feed to the front
