Page 2 of 5 1 2 3 4 5
Re: The weekend lowering project [Re: mopeman] #795144
09/08/10 12:35 AM
09/08/10 12:35 AM
MO
cdp Offline
cdp  Offline
MO
A friend is doing an 84 Stepside. He was wanting to lower his too, but didn't know what to do on the front.
What year LCA's are you using? Are they out of your typical dodge van?
Chris
Re: The weekend lowering project [Re: adventurer] #795145
09/08/10 12:55 AM
09/08/10 12:55 AM
Brian123 Offline
Brian123  Offline
Hows does it ride?
1989 D-250,360/727
Re: The weekend lowering project [Re: adventurer] #795146
09/08/10 02:27 AM
09/08/10 02:27 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Looks good! I'd love to find a nice clean truck like that to do something similar. I'd ditch the rear bumper and get one of those fiberglas rear pans. I'd also change to a 89/90 grille and a 70s front bumper.
I've been kind of thinking the same thing on the bumpers and grill. Just not completely decided what to do there yet. Thanks
Just remember the 81-85 86-90 and 91-93 have diff headlight locations. 81-85 and 86-90 are very close and grill setup can be swapped but you can see the headlight diff. Easy way is swap core support or if you can weld that way works too but 91-93 the core support and lower valance are needed aswell Looks good. My tires on my 73 Clubcab sat where yours do in the wheelwells in front but I had 205/75s. I have some pocketed control arms I plan to use with drop coils on my D code 74
Re: The weekend lowering project [Re: mopeman] #795147
09/08/10 07:10 AM
09/08/10 07:10 AM
It's beer:30 somewhere
adventurer Offline OP
Nice job, looks great..plan on doing the same to my '85. Where did you get the drop shackles?
I got them from Ebay. Here is a link to the exact one I used. http://cgi.ebay.com/ebaymotors/2-LOWERIN...=item588974c570
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: The weekend lowering project [Re: cdp] #795148
09/08/10 07:13 AM
09/08/10 07:13 AM
Chris
Mine came from a 82 3/4 ton van. The junkyard I went to had several of these vans one as new as 90 and the arms all looked the same. Maybe someone else with a little more knowledge can chime in and say what exact year models work. My understanding is any 3/4 or 1 ton van in those year models.
14 Ram R/T
Re: The weekend lowering project [Re: Brian123] #795149
09/08/10 07:14 AM
09/08/10 07:14 AM
Hows does it ride?
Very well. Not much differnt than before it was lowered.
14 Ram R/T
Re: The weekend lowering project [Re: adventurer] #795150
09/08/10 09:25 AM
09/08/10 09:25 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Hey Larry I used stock shocks when I did mine I think I'm going to change them to something a little stronger....What did you use? The same on the back. The Truck is good on semi smooth road but a bear on those bad roads.
Re: The weekend lowering project [Re: adventurer] #795151
09/08/10 09:52 AM
09/08/10 09:52 AM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
Chris
LCAs from B250s as well as newer B2500 are will work until at least '97 (mine are from a '97 B2500)
Re: The weekend lowering project [Re: adventurer] #795152
09/08/10 10:17 AM
09/08/10 10:17 AM
Lehigh Acres, Florida
rickstershemi Offline
Clean looking truck Larry....Lucky Daughter
One thing more to do is: remove the factory Alignment Cam Adjuster Stop Plates so you can get more adjustment....ours needed the xtra range to get back to the factory alignment specs
Rickster
Rickster thanks for the advice. I really don't know what plates you are talking about could you please explain more and maybe a picture. The only plates I see are the one that the cam pushes against to adjust. Is that the one you are refering to? Thanks
Larry
Yes those are the plates I'm referring too....had to remove them on our truck to get additional range to be in spec
Rickster
Re: The weekend lowering project [Re: Webster] #795153
09/08/10 10:41 AM
09/08/10 10:41 AM
Hey Terry,
I only changed the front shocks because I had the old ones out and they looked like the originals. I just used a stock replacement shock for it. The rears had been changed at some point and time. I'll have to drive it more to see how the ride is after I get it aligned on Thursday. so far I really don't see that much diffence in ride quality. On the front shocks changing the arms really didn't shorten the shock travel because the mounting point for the shock is lowered as well. So I wouldn't think changing the shock to a differnt shock on the front would help. Maybe cutting down the rubber bump stop. Now on the rear thats a diffenrt story. By lowering the truck it has shortened that shocks travel and it could be bottoming out. I am just going to drive it and see. If it feels harsh as far as bumps that it may be bottoming the shock out, I'll find a shorter shock for the rear. Maybe my roads are just smoother than your's Terry
14 Ram R/T
Re: The weekend lowering project [Re: adventurer] #795154
09/08/10 01:55 PM
09/08/10 01:55 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Hey Terry,
I'm sure your roads are better than ours
I cut the bump stops off of mine when I first lowered mine, no issue so far (over 5 Years) you might be right about the back shocks bottoming out ,I'll check too
Re: The weekend lowering project [Re: Webster] #795155
09/09/10 12:01 AM
09/09/10 12:01 AM
Mopar366 Offline
Mopar366  Offline
what kind of chevy are the 2" drop shackles off of? and what year van for the lca's
1982 d150 1993 dakota
Re: The weekend lowering project [Re: Mopar366] #795156
09/09/10 12:44 AM
09/09/10 12:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The LCA's come from the 1st year B van to 2001 that I know of with 5 lugs. 1st year being 71 or 72.The shackles I use are 88-98 Chevy 1500. I'll be doin the same to my daughter's white shorty soon.
Re: The weekend lowering project [Re: Mopar366] #795157
09/09/10 01:46 AM
09/09/10 01:46 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You can go to autozone and get the drop shakles for $30
Re: The weekend lowering project [Re: Mopar366] #795158
09/09/10 11:39 AM
09/09/10 11:39 AM
Heres a link to the exact drop shackles I used.
LCA I used were from a 82 3/4 ton van.
14 Ram R/T
Re: The weekend lowering project [Re: adventurer] #795159
09/09/10 02:31 PM
09/09/10 02:31 PM
Those are the same exact shackles we used
Rickster
Re: The weekend lowering project [Re: rickstershemi] #795160
09/12/10 01:20 AM
09/12/10 01:20 AM
Latest update. Got the alignment done. While doing the alignment noticed the lower bump stop rubber bumpers were setting against the lower control arm at ride height. Unbolted them while doing the alignment. Which I beleive is going to be a mistake. Got the new wheels on today and really drove it quite a bit. When you hit a large bump in the road the lower control arm is coming in contact with the metal where the rubber bump stop bolted on and you get a loud clunk noise. So I am going to look into what I need to do for that. Any body else have an idea there? Now on to the pics of it as it is right now.
just for comparison here is where I started
Quite a bit of differnce there, if I do say so myself. I think it looks a lot better.
14 Ram R/T
Re: The weekend lowering project [Re: adventurer] #795161
09/12/10 01:43 AM
09/12/10 01:43 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
When I did mine, I drove it to the end of the street and saw the same thing. Cut them off and had no trouble after that. If I hit that big of a bump she all over with anyway
Your Truck is lookin really Good
Re: The weekend lowering project [Re: Webster] #795162
09/12/10 10:09 AM
09/12/10 10:09 AM
did the same thing....have had no problems although we didn't remove them I just trimmed them up 1" and never hits, but there if an extreme pot-hole may be encountered
Rickster
Re: The weekend lowering project [Re: rickstershemi] #795163
09/12/10 04:31 PM
09/12/10 04:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
When I cut a coil and a half out it sat on the bumpstop brackets(rubber was gone)I drove it that way for just over a yr before the motor gave and I live 25 miles from work. Mine was my dd so couldnt really tear it back apart but it was only rough when the roads were bad. I chanded the travel aswell so the coils wouldnt flop around when the suspension was working
