Reccomend a shop for B Body heater core (w/ ac) fix?
#790174
09/01/10 04:39 PM
09/01/10 04:39 PM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
I finally did it! I wrestled the damn heater core out of the car. What a nightmare. But hopefully the nightmore is over, if someone can reccomend a good shop to take this to. I see a corroded spot in the core where it appears to be leaking, though I haven't pressure checked it myself. I can't really get the core out of the housing.
I'm hoping there's an expereinced shop/member that can help me out. Any reccomendations?
"Broke is temporary, cheap lasts forever"
Re: Reccomend a shop for B Body heater core (w/ ac) fix?
[Re: stumpy]
#790176
09/01/10 05:24 PM
09/01/10 05:24 PM
Posts: 2,592 None
71rm23
None
Check the local parts stores for a replacement. It will be cheaper then having your old one fixed in most cases.
Hopefully. As stated, check around first. When I did mine, the heater core cost $38. I ended up restoring the whole heater box. Total cost was $180. That was with new caskets, seals, paint, etc. Guess it depends on whether or not you're restoring the whole thing or just wanting to fix the core. Just my
[Re: stumpy]
#790177
09/01/10 07:15 PM
09/01/10 07:15 PM
68Bullet
Oakland, CA
I've checked thoroughly, they are not readily available for cars with AC. There is also some sort of specialty valve that I have been told may leak. That's why I'm hoping to find someone with knowledge of this particular part.
[Re: 68Bullet]
#790178
09/01/10 07:37 PM
09/01/10 07:37 PM
Posts: 2,592 None
71rm23
None
[Re: 71rm23]
#790179
09/01/10 08:02 PM
09/01/10 08:02 PM
68Bullet
Oakland, CA
Yes, very important detail! It's a 68 coronet, factory AC car.
[Re: mr_belvedere]
#790183
09/02/10 01:44 AM
09/02/10 01:44 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The heater control valve is a pretty common problem. They pop up NOS or rebuild on the b body parts for sale section or epay.. 70 is a one year only deal... A member said that NAPA sells repair kits for them, in a long ago post...
