Reccomend a shop for B Body heater core (w/ ac) fix? #790174
09/01/10 04:39 PM
09/01/10 04:39 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I finally did it! I wrestled the damn heater core out of the car. What a nightmare. But hopefully the nightmore is over, if someone can reccomend a good shop to take this to. I see a corroded spot in the core where it appears to be leaking, though I haven't pressure checked it myself. I can't really get the core out of the housing.
I'm hoping there's an expereinced shop/member that can help me out. Any reccomendations?
"Broke is temporary, cheap lasts forever"
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: 68Bullet] #790175
09/01/10 04:52 PM
09/01/10 04:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the local parts stores for a replacement. It will be cheaper then having your old one fixed in most cases.
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: stumpy] #790176
09/01/10 05:24 PM
09/01/10 05:24 PM
None
71rm23 Offline
71rm23  Offline
None
Hopefully. As stated, check around first. When I did mine, the heater core cost $38. I ended up restoring the whole heater box. Total cost was $180. That was with new caskets, seals, paint, etc. Guess it depends on whether or not you're restoring the whole thing or just wanting to fix the core. Just my
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: stumpy] #790177
09/01/10 07:15 PM
09/01/10 07:15 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I've checked thoroughly, they are not readily available for cars with AC. There is also some sort of specialty valve that I have been told may leak. That's why I'm hoping to find someone with knowledge of this particular part.
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: 68Bullet] #790178
09/01/10 07:37 PM
09/01/10 07:37 PM
None
71rm23 Offline
71rm23  Offline
None
Year of car?
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: 71rm23] #790179
09/01/10 08:02 PM
09/01/10 08:02 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
Yes, very important detail! It's a 68 coronet, factory AC car.
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: 68Bullet] #790180
09/01/10 08:15 PM
09/01/10 08:15 PM
IN
ahy Offline
ahy  Offline
IN
Classic Auto Air in Florida took care of mine (70 E with AC). They repair and stock replacement cores, vacuum pots and other parts.
I sent my whole box in for overhaul; they did a great job. Its running fine about 5 years later with a Sanden compressor up front.
If you want to DIY, in addition to the FSM, Mopar Muscle had a decent article on their website on overhaul of the box.
Re: Reccomend a shop for B Body heater core (w/ ac) fix? [Re: ahy] #790181
09/01/10 08:18 PM
09/01/10 08:18 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Re: Reccomend a shop for B Body heater core (w/ ac) fix [Re: rrunner] #790182
09/01/10 08:40 PM
09/01/10 08:40 PM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
Send it to Bob at Glen-Ray Radiators.
Re: Reccomend a shop for B Body heater core (w/ ac) fix [Re: mr_belvedere] #790183
09/02/10 01:44 AM
09/02/10 01:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The heater control valve is a pretty common problem.
They pop up NOS or rebuild on the b body parts for sale section or epay.. 70 is a one year only deal...
A member said that NAPA sells repair kits for them, in a long ago post...
Re: Reccomend a shop for B Body heater core (w/ ac) fix [Re: sthemi] #790184
09/03/10 10:41 AM
09/03/10 10:41 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Be warned that many of the aftermarket cores do NOT fit properly. Since you have the original core you are better off restoring the original. I also agree with the other reply that recommended sending it to Bob at Glenray radiators for recore / restoration.
Re: Reccomend a shop for B Body heater core (w/ ac) fix [Re: C_B5] #790185
09/03/10 11:03 PM
09/03/10 11:03 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Call Todd at http://alouisradiator.com/ I bought my heater core from him last year. They are in S.F.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
