Big Block exhaust to head pipe #786608
08/28/10 10:50 PM
08/28/10 10:50 PM
Buzzardbreath Wyoming
BigBird Offline OP
BigBird  Offline OP
Is there a good way to keep from getting an exhaust leak between the manifold and the head pipe? I've filed the flanges on both the manifold and pipe flat, installed a new gasket with high temp RTV and it still leaks after 100 miles. I've tried steel gaskets as well as fiber gaskets with little luck. Anyone else fighting this problem?
Re: Big Block exhaust to head pipe [Re: BigBird] #786609
08/28/10 11:03 PM
08/28/10 11:03 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
That one can be a pain.
Be sure your motor mounts are in good shape to limit excess engine movement--that can wreak havoc on the joint. DAMHIK
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Big Block exhaust to head pipe [Re: BigBird] #786610
08/29/10 09:29 AM
08/29/10 09:29 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Is the exhaust system hung correctly with correct flexible hangers? Too many times I've seen the exhaust pipes hanging from cheapo universal hangers in a configuration that actually prevents flex.
Re: Big Block exhaust to head pipe [Re: Commando1] #786611
08/29/10 06:20 PM
08/29/10 06:20 PM
BigBird Offline OP
BigBird  Offline OP
It's on factory hangers on a restored car. They seem to move ok and the engine mounts are in good shape as well. I've had the same issues on my big block pickup until one set finally just held. Saw nothing that I had done different than any of the others. It is easy enough to change them but there has to be some trick to make them work the frist time.
Re: Big Block exhaust to head pipe [Re: BigBird] #786612
08/29/10 06:44 PM
08/29/10 06:44 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
I had to double up on the flange gaskets with ultra copper between them and on the outer sides. Next time I have them apart, I think I'll try Remflex gaskets.....
69 Roadrunner 383 stock
Re: Big Block exhaust to head pipe [Re: Jim_S] #786613
08/29/10 07:04 PM
08/29/10 07:04 PM
BigBird Offline OP
BigBird  Offline OP
Never heard of Remflex? I did the double gasket with high temp RTV last time with no luck.
Re: Big Block exhaust to head pipe [Re: BigBird] #786614
08/29/10 07:22 PM
08/29/10 07:22 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The flange gaskets TTI sells worked best for me.
Re: Big Block exhaust to head pipe [Re: bobby66] #786615
08/29/10 10:23 PM
08/29/10 10:23 PM
scratchnfotraction Offline
change the flat flange on the head pipe IMHO
stop fighting the warped one on the end of the head pipe
over torqueing the flange will warp them,gone as many as 3 gaskets with copper rvt to seal them
now thats shade tree right there
40 bones and it was done up with a nice one at the muff shop
never another problem with it
