Truck 440 build advice
#786205
08/28/10 12:22 PM
08/28/10 12:22 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
I have a half ton, mid seventies dodge truck with a 440, 727, and 9.25. I am looking to select another motor to rebuild and swap out with this engine. What year motor would be best? Cast or forged crank? What compression for the build? Which camshaft? I intend to run the factory iron 452 heads, but also would consider the motor-home head if I find a set. The truck is used for mostly hauling stuff in the bed like motors, trans, rear-ends. I do also use the truck for hauling cars/boats on trailers usually less than 5000lbs. Should I use a 440 from a motor-home and keep the compression low for towing? What size convertor should I use, and which cam? Rear gears are Suregrip 3:21. Thanks!
Some people you just can't reach...
Re: Truck 440 build advice
[Re: Suregrip]
#786207
08/28/10 01:01 PM
08/28/10 01:01 PM
Posts: 4,064 Boca Raton, Florida
jpilone
Boca Raton, Florida
What are you looking to accomplish with the truck? Tow Rig? Daily Driver? Etc??
-Jarrod Pilone '70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit) My Project Thread
[Re: dOc !]
#786210
08/28/10 01:06 PM
08/28/10 01:06 PM
Suregrip
Fort Lauderdale, FL
Right now I can pick up a 67 440, 68 440, 73 440, and a 69 440. They are all car motors except for the 73 which is from a motor home. The 73 might have the eight bolt crank and peanut plugs in the heads, but not sure yet. They are all complete and good running condition. Not really too interested in a 413 since years from now I might need to use this engine again in a car build. Plus pistons are limited for a 413 build. I am also looking for lots of low and mid-range torque so I need the cubes...
[Re: Pacnorthcuda]
#786212
08/28/10 01:11 PM
08/28/10 01:11 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Doc....you seriously have 413 on the brain. You should broker a swap with the other guy with the 413.
You THINK ? .. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Suregrip]
#786213
08/28/10 01:16 PM
08/28/10 01:16 PM
Suregrip
Fort Lauderdale, FL
The truck will be a daily driver(less than 20 miles) and a tow-rig maybe three or four times a month. I plan on running a Eddy dual plane and T-Quad as that's what I have been running for years on the truck. It currently has a no-name RV cam. I will continue to use the factory center-dump exhaust with full duals. So I guess I am reall wondering about compression, cam, factory head choice between 1972-1978. I could re-use my current 452s, should I use the motor-home heads? What is the number for them and do they flow the same as all the rest of the heads. I have read the articles about the factory heads but I am not sure if they covered the motor-home head?
[Re: ahy]
#786215
08/28/10 02:08 PM
08/28/10 02:08 PM
Posts: 7,664 IN
ahy
IN
[Re: Suregrip]
#786216
08/28/10 04:07 PM
08/28/10 04:07 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
My 76 MH 440 has 452 heads with peanut plugs.
[Re: dodgeram440]
#786217
08/28/10 04:53 PM
08/28/10 04:53 PM
Posts: 15,487 Florida
scratchnfotraction
78 MH 440/4-v/452 peanut plug heads/center dump manifolds with 75,000 miles here in my 88 truck build used the short shaft MH 727 with a CRT full manual valve body for no TPV linkage also custom xmember/stock MH TC with an a-body 8 3/4 3.91sg thats it in the sig pic,nice and simple street truck ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#786218
08/28/10 06:03 PM
08/28/10 06:03 PM
Suregrip
Fort Lauderdale, FL
Thanks for all the replies so far. I would still like to hear compression, piston, cam, convertor, recommendations... Remember I am looking for torque, durability, cost, mileage, in that order. Another question, were 400s put in motor-homes? I was under the impression they were all 413s and 440s in the 70s...
[Re: moparmanof85]
#786220
08/28/10 06:39 PM
08/28/10 06:39 PM
Suregrip
Fort Lauderdale, FL
Thanks, didn't know about the 400s in the motor-homes. I am considering just pulling my 1977 440 out of the truck and just re-building it. I really didn't want the truck down that long but it might be the most cost effective way to do this. I would still like to hear what you guys think about piston, cam, convertor, for a truck which does a fair amount of towing. Remember half ton, 727, 9.25 with 3:21 SG...
[Re: dodgeram440]
#786224
08/28/10 07:28 PM
08/28/10 07:28 PM
Suregrip
Fort Lauderdale, FL
I think you are correct about the torque and the towing with a stroker in the 440. I will check into kits from 440 source. Anyone else I should look at for a kit? I didn't want to get too crazy with the cost beyond that for a quality rebuild though... I would think I could get close to 500 foot pounds of torque out of a well rebuilt 440. Question remains though, which cam, piston, convertor, etc...
