Re: cross ram bb question:.....
[Re: moparmanof85]
#781795
08/23/10 08:38 PM
08/23/10 08:38 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
its got the high rise water pump and the heads are maybe 1-2 inches taller than standard. its an industrial, i think.
That head takes a special intake , a crossram will not bolt to them , they are no good to you for what you want to do , I assume put it in a car ???
[Re: moparmanof85]
#781801
08/23/10 10:39 PM
08/23/10 10:39 PM
JohnRR
thought about it. its a low torque engine though. thinking truck. funny... the intake manifold gasket from a regular kit is perfect. the kit is to a 413, the valve covers are to a 400, and the exhaust manifolds are 361. weird, huh?
Ok , that I did not know, from pics of the intakes I have seen they APPEARED different , but as you said if the heads are TALLER by a couple inches the crossram is going to hit the valve covers .
[Re: moparmanof85]
#781807
08/24/10 08:18 PM
08/24/10 08:18 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
New water pump housings are a dime a dozen. If you really want a crossram don't let the water pump stand in your way.
very clever dinner. appetizing food fit neatly into interesting round pie.
[Re: HitIt]
#781808
08/24/10 08:24 PM
08/24/10 08:24 PM
Posts: 15,487 Florida
scratchnfotraction
what kind of square stock pieces are on the tranz and bell housing in the back ground?? ![](/ubbthreads/images/graemlins/scope.gif) that looks as odd as the industy water pump and heads ![](/ubbthreads/images/graemlins/whistling.gif) nice and orange too ![](/ubbthreads/images/graemlins/drool5.gif) is that the fan spacer laying in/on the intake front in the first pic ![](/ubbthreads/images/graemlins/shruggy.gif) i would run it just for the kool and different factor in my truck cant be that bad of engine for a driver,deff different looking in a sea of mundane BB out there ![](/ubbthreads/images/graemlins/popcrn.gif)
