So I tried starting the doba last fall and discovered a knock up front. never got it started, so I initially thought timing chain. got down to that and discovered that not to be the problem, but a sticky valve, or lifter problem/cam. if I decide to increase HP down the road, what is the best cam for now.. what is the best purple shaft for some strip action
