Page 1 of 8 1 2 3 4 5 6 7 8
Thermoquad vs. Six Pack/Six Barrel. Which is best ? #779572
08/21/10 02:36 PM
08/21/10 02:36 PM
Desert Tracker
HYPER8oSoNic Offline OP
Desert Tracker
Thermoquad vs. Six Pack/Six Barrel. Which is BEST for BOTH power and efficiency on the street, on both big and small blocks? Any opinions or facts?
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779573
08/21/10 02:49 PM
08/21/10 02:49 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
H-guy ....whatchootryintodo ... stir-up a bunchO Berri-Bumz HORNET's nest ?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779574
08/21/10 02:53 PM
08/21/10 02:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Six-Pak, FACT.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: Pacnorthcuda] #779575
08/21/10 02:56 PM
08/21/10 02:56 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
The PAC-man is a died-in-the-wool Berri Bum ... his opinion does not count !!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779576
08/21/10 02:59 PM
08/21/10 02:59 PM
wishing you and your trees a Holley-Jolley Xmas Doc!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: Pacnorthcuda] #779577
08/21/10 03:05 PM
08/21/10 03:05 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Hay Pac ..... and may that Holly spiney-BUSH stick-ya' .....
And NOW I uNderstand why you have that wording below yurr name ....DOWN SHIFTING .....
Ya gotsta' do dat to clean the motor out from that pig-fat Berri Crab !
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779578
08/21/10 03:24 PM
08/21/10 03:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Kinda depends, lot easier to put the t-quad on a good manifold. The 6 pack problem is the manifolds not the carb, unless you are me and can't get a holley to run right for nothin. T-quads run great and are easy to work on.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HotRodDave] #779579
08/21/10 03:27 PM
08/21/10 03:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
gets to be a pain to jet a t-quad when there are no aftermarket jets and rods. i have to scrounge for jets and drill them out on the lathe to get A/F ratio close.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HotRodDave] #779580
08/21/10 05:26 PM
08/21/10 05:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
6 pack baby. over 1300cfm
Coming soon!!!!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: Mr.Yuck] #779581
08/21/10 05:36 PM
08/21/10 05:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They only flow 1300 if you flow them a 3.0 inches like 2bbls aree flowed. If you flow a 6pk at 1.5 like the 4bbls are then it will strugle to flow 1000 cfm, or about the same as a good T-quad and you are still stuck with a 6pk manifold, a simple adapter can fit a t-quad to just about any manifold.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HotRodDave] #779582
08/21/10 06:25 PM
08/21/10 06:25 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
HotRodDave has it right. According to the resident Mopar junky over at Hot Rod Magazine (David Freiburger,) in terms of 4-barrel air flow the mighty Six-Pack flowed closer to 975cfm because 2-barrel carbs are rated using different specs.
Throw on a street tuned Holley 950HP on an Edelbrock Performer RPM intake and there you go...
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: ademon] #779583
08/21/10 06:58 PM
08/21/10 06:58 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
As someone who has run both I'll take a TQ anyday.
I have two TQ strip kits on the shelf!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: gdonovan] #779584
08/21/10 08:18 PM
08/21/10 08:18 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Better selection for single 4 manifolds than six pack for starters. A properly setup thermoquad will deliver better fuel economy and more horsepower. Dave
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: quickd100] #779585
08/21/10 08:52 PM
08/21/10 08:52 PM
Under My Car
Mopar_Country Offline
Under My Car
Better throttle response too.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779586
08/21/10 09:07 PM
08/21/10 09:07 PM
Desert Tracker
Desert Tracker
I guess I woke you up from the DEAD!!
What's your take on this?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HYPER8oSoNic] #779587
08/21/10 09:15 PM
08/21/10 09:15 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
My take ? .... I think I should make a TON of T-shirts proclaiming .....The ThermoSquad is alive and well !!
And from what I have seen and read ...Mayor Dave has done a ton-O-work of the TQ when it comes to a E85 conversion ...
I have not done much lately on TQ R&D and tweaking as he has .... we should get HIS TAKE ...and maybe Scott's.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: HotRodDave] #779588
08/21/10 09:19 PM
08/21/10 09:19 PM
Desert Tracker
Desert Tracker
Good point to about, Dave! I was wondering why when you increase the cubes, especially 440 strokers, you get an abundance of
low to midrange torque and decent mileage (provided the cam, compression and ignition timing
are correct for the combo)in a middle weight chassis (B-body stripper model) with the six pack induction.
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: dOrk !] #779589
08/21/10 09:25 PM
08/21/10 09:25 PM
Desert Tracker
Desert Tracker
Good food for !! That E85 fuel may be the
answer to the cost of cruising. Good input Doc,
I figured you to come up with a answer WITHOUT the
added sarcasm!!
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: quickd100] #779590
08/21/10 09:38 PM
08/21/10 09:38 PM
Desert Tracker
Desert Tracker
Dave, comparing a six pack to a TQ setup, on a
stroker (440/500) built for dual purpose, which
would net a tractable, but powerful setup? Six
packs have been known to do well with bigger displacements, but I know there's a limit.
TQ's are very responsive, but have their parameters also. What do you think?
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ? [Re: CompSyn] #779591
08/21/10 09:42 PM
08/21/10 09:42 PM
Desert Tracker
Desert Tracker
But being so close in airflow, would the six pack
have more flow capability upstairs? Due to the two extra venturis? Or not.
