Re: HELP- Broke Rear End on 65 Belvedere....... (DANA)
[Re: ZIPPY]
#778448
08/20/10 04:00 PM
08/20/10 04:00 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Alot of gears have a date code on them...it'd be intresting to see how old it is
I think they must be pretty old.... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I have owned the car for 5 years now,,,,and Bobby ran the car for several years prior to that..... ![](/ubbthreads/images/graemlins/drive.gif)
LOTS of runs on the car in the past 5-8 years...... ![](/ubbthreads/images/graemlins/runaway.gif)
Local guy is very good at setting gears up...should work out fine....... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 69CHARGERMD]
#778453
08/21/10 10:34 AM
08/21/10 10:34 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
It's OUT...........
![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/P8200011.jpg)
That looks familiar ....mine was out a few weeks ago for the Locker upgrade and is now back in with the Caltrac setup. ![](/ubbthreads/images/graemlins/thumbs.gif)
Get that thing fixed and ready for Norwalk ! ![](/ubbthreads/images/graemlins/beer.gif)
Ron
[Re: Leigh]
#778456
08/30/10 07:05 PM
08/30/10 07:05 PM
69CHARGERMD
KENTUCKY
UPDATE: Got the rear back,,,all set up with the new PRO gears,, ![](/ubbthreads/images/graemlins/beer.gif) Questions ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) 1) Do you guys run a GASKET on the diff cover ? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) or just lots of gasket adhesive ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ( was going to use the black gasket material adhesive ) 2) What gear lube to run ? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) My buddy that set it up mentioned the heaviest weight Red Line gear lube i could find....Does anyone have a specific recomendations ? Is there something that Autozone would have,,? Hope to have it all back together in the next few days... Going to change the Master Cylinder while i am at since i have to bleed the brakes.... ![](/ubbthreads/images/graemlins/runaway.gif) Should be ready for Norwalk,,,,,,,, ![](/ubbthreads/images/graemlins/thumbs.gif) Doug
[Re: 69CHARGERMD]
#778459
08/31/10 07:38 AM
08/31/10 07:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
UPDATE:
1) Do you guys run a GASKET on the diff cover ? or just lots of gasket adhesive ( was going to use the black gasket material adhesive )
2) What gear lube to run ? My buddy that set it up mentioned the heaviest weight Red Line gear lube i could find....Does anyone have a specific recomendations ? Is there something that Autozone would have,,?
Doug
Doug I use black Mopar RTV and I use 90 weight... I dont understand why he wants you to use the heaviest oil... the pro gear is softer to take the shock... glad your all set again... did you figure out the tire to fender issue
![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#778460
08/31/10 07:10 PM
08/31/10 07:10 PM
69CHARGERMD
KENTUCKY
Thanks guys,,, Mike, regarding the tires/rims, I ended up getting a different offset rim,,,this took care of it,,moved everything about 3/4-1",,no more risk of snagging a slick i hope. ![](/ubbthreads/images/graemlins/hammer.gif) My buddy mentioned 90 weight as well,,,must be what he refers to as "heavy" weight... ![](/ubbthreads/images/graemlins/popcrn.gif) He said the previous gears were set up very well,,,,thinks i had sheared off a bunch of teeth from dry hopping the car out of the water,,he said they could have been like that for a while,,,and i just didnt realize it. ![](/ubbthreads/images/graemlins/drive.gif) (no Norwalk ?,,,everything OK ? ) ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Jim,,, Quote:
Did you need a new pinion bearing (large one)
Nope,,,he took care of it,,,i hope it's a bolt and go outcome,,,should be..... ![](/ubbthreads/images/graemlins/beer.gif)
Doug
See you guys in Norwalk,,,,,
