Re: New clutch and big snap and now nothing
[Re: DAYCLONA]
#778044
08/19/10 11:08 AM
08/19/10 11:08 AM
Posts: 5,443 ME
79machocharger
ME
[Re: DAYCLONA]
#778045
08/19/10 11:15 AM
08/19/10 11:15 AM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Probably sheared the hub out of the disc if you didn't break anything in the trans or diff. The last time I had one go bang and then nothing I put it in gear and the drive shaft turned but the wheels didn't ![](/ubbthreads/images/graemlins/laugh2.gif) . Kevin
[Re: 79machocharger]
#778046
08/19/10 12:15 PM
08/19/10 12:15 PM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
What exactly do you mean by "grinding"? The fork cannot come off - not really. The plate that was mentioned - would be the friction plate. You'll have to disassemble to know the truth... (I have a new clutch in my own 1970 Challenger - and, well, that sounds ![](/ubbthreads/images/graemlins/eeek.gif) interesting ![](/ubbthreads/images/graemlins/eeek.gif) to me. Didn't know that this ever can happen... I have Centreforce in, hope this lasts longer. Hope that YOU are the one of 10'000 guys ![](/ubbthreads/images/graemlins/biggrin.gif) that makes this happen once in hundred years.)
After all these years having a 440 I realized that this means having an attitude... and a budget.
[Re: Twostick]
#778051
08/19/10 04:50 PM
08/19/10 04:50 PM
Posts: 2,826 NY usa
540challenger
NY usa
Probably sheared the hub out of the disc if you didn't break anything in the trans or diff. The last time I had one go bang and then nothing I put it in gear and the drive shaft turned but the wheels didn't .
Kevin
Sounds about right. Also i would be there when they drop the tranmission. They olnly times i see a hub snap with low miles is when somehting was misaligned last time i changed one out the tranmission shop had the engine wire harness wedge between the block and bell housing cause a misalignment and the hub to fail.
[Re: hemigod426]
#778058
08/19/10 09:09 PM
08/19/10 09:09 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I gotta ask.... A shop is hired to work on the car(install a new clutch), then takes the clutch down for nothing. Do they have the capability to figure out the problem or are they just doing what you tell them to do? Maybe you need a new mechanic ![](/ubbthreads/images/graemlins/Twocents.gif) MB
#778061
08/20/10 11:34 AM
08/20/10 11:34 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
If it kind of moves but grinds Id say trans or rear.With the drive shaft out the rear should be easy.Just try turning the yoke and see if the wheels turn or if it makes noise.Sounds like you broke something.Same with the trans.Put it in gear and see if the output shaft turns or if it makes noise.Rocky
Chrysler Firepower
