For all those that thought it was the rear end you were right(lol). I just thought since every thing was fine before the clutch install it was the clutch. I'm fine with the whole deal as I now have a better clutch set up in my car. I'm going to use the rear out of my project challenger t/a untill my original one is fixed. Mine had 3:23's and the t/a has 3:55's which should be alot more fun any way
![](/ubbthreads/images/graemlins/thumbs.gif)
The funny thing is we drained the fluid in the rear to see if we could see any metal peices and we saw nothing. I also tried turning the wheels while holding the pinion and we couldn't. I also checked in and out play at the tires and pinion and none, alittle at the tires but normal. Just wanted to say thanks for all the help
