How do I identify `70 E body 383/440 26” max cool radiator fan ?
If anyone has their original fan could you tell me the number of fan blades, outer diameter blade tip to blade tip, depth/ offset distance blade from pulley ?
My cuda engine temp has been higher this summer at idle using my Mopar Perf pkg fan, my MP fan clutch does not have as much grap resistance as I think it should & I found a similar sized vintage factory clutch fan that the clutch has double the resistance so it grabs the shaft tighter , that I could use that would still look stock, “but” it has more blades, slightly less offset, and it is slightly large diameter at the blades, but it looks like it will bolt up and fit in the shroud OK. Can't see any part #'s on this spare vintage fan.
Is my MP viscous fan pkg clutch the same operating type as the OEM torque vs thermal ? Mine with the engine off you can spin the fan blade few inches before the resistance stops it, is this normal ?
thanks SCHU.
dougandcindy@sympatico.ca
