Re: Caltracs with Stock leafs [Re: mshred] #773054
08/15/10 07:17 PM
08/15/10 07:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
Not very long, only about half the season. Maybe 50 passes and 500 street miles.
Pinion angle should be a couple degrees nose down, about 2 I think. Always best to call them and ask. Their customer service is top notch.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Caltracs with Stock leafs [Re: Triple Threat] #773055
08/16/10 08:42 AM
08/16/10 08:42 AM
an8sec70cuda Offline
The same mono springs have been on mine for about 8 years.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Caltracs with Stock leafs [Re: mshred] #773056
08/16/10 08:50 AM
08/16/10 08:50 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
IT SAYS DO NOT USE W SS LEAF SPRINGS...NOT RECOMENDED! spend the $ and get the split leafs u wont be sorry.
Re: Caltracs with Stock leafs [Re: fishy340] #773057
08/16/10 01:25 PM
08/16/10 01:25 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have Cal-Tracs & 1" lower that stock height split momo's with a 1" relocation Doctor Diff kit to get 315 Drag Radials on the back of my 70 Challenger. I was told if you are going to run Caltrac's with any serious power then also add the split mono's. I have yet to test them out.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Caltracs with Stock leafs [Re: fishy340] #773058
08/16/10 07:33 PM
08/16/10 07:33 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I dont have SS springs, just stock 6cyl leafs...before the monos came out from calvert, thats what people were using i believe
thanks for all the opinions thus far...im surprised that you all have put so many years on your monos when calvert told me they will wear out very quickly...guess it depends on how many miles you drive?
ill have to look into the pinion angle thing when i call them i guess, as it might make a difference being that my car is a stick
thanks all for the suggestions and replies! has made my choice much easier thats for sure
Re: Caltracs with Stock leafs [Re: mshred] #773059
08/17/10 12:24 PM
08/17/10 12:24 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I had a local manufacturer make a couple pair of 1/2" one pc mono-leafs for me to my specs.
John Calvert advised me what to look for as far as measurements relating to ride hgt car wght and spring arch. This was 10 years ago.
Back then we were discussing the feasability of fiberglass leafs, dont know if it ever came to fruition.
If I recall the six banger springs are identical left and right, you have to look at what you have.
Re: Caltracs with Stock leafs [Re: theclutcher] #773060
08/17/10 07:09 PM
08/17/10 07:09 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i just fitted caltracs to my 68 satellite
i have mopar XHD leaf springs,extra on right
it smoothed out the launch a bunch,no change to sixty.this is with equal ,1/4 turn,preload both sides.
car is a lot more square on launch
still have to see how tight rear shocks need for the strip.
this pic without caltracs
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Caltracs with Stock leafs [Re: tex013] #773061
08/17/10 07:11 PM
08/17/10 07:11 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
this pic with caltracs,i think this was early and had too soft rear shock setting
Tex
New best MPH 130.32
Re: Caltracs with Stock leafs [Re: tex013] #773062
08/18/10 11:00 PM
08/18/10 11:00 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Tex, that first pic is the same way my car launches. Really squats like a chevy. Looks like the Caltracs really helped level out the launch. Probably feels better out of the hole too.
Don.
Re: Caltracs with Stock leafs [Re: MoparDonny] #773063
08/24/10 07:09 PM
08/24/10 07:09 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Don,
gees i'm late on the reply.
this is the only shot i have seen so far with caltracs fitted.
Yes the car does launch squarer.
Yes the car does launch a LOT smoother.It used to launch very violently,flip the mirror etc.Feels like an elevater now
Does not,so far,seemed to have shortened 60' just made it more consistant.that night went 1.599,1.606,1.593,1.593.
Tex
New best MPH 130.32
